400 small blocks
Discussion in 'The Garage' started by SwanGuy, Oct 16, 2002.
  1. SwanGuy
    SwanGuy Registered Member
    Oct 16, 2002
    6
    Swartz Creek, MI
    I recently blew up my 350 and now am considering replacing it with a 400 small block, what should I know about this motor before I go and pick one up?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    They do not like high RPM as much. Thats what killed mine. They also need a good radiator as they like to heat up more. Other than that, I liked mine. Gave me years of good service. Oh, yeah. Get the flexpate for it. the 400's have externally balanced ones and will not interchange with the other small-blocks.
  3. SwanGuy
    Oct 16, 2002
    6
    Swartz Creek, MI
    You mention flexpate, what does it look like and what does it do? When it comes to motors I know very little. As far as tranny's go, I can rebuild 350's and 400's with my eyes closed...ha!
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Its the big round thing that bolts to the crank. the converter bolts to this (if automatic). Hope this helps.
  5. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thats back of the engine not the front. Thats the balancer. You'll also need that as it is different than the other small-blocks.
  6. SwanGuy
    Oct 16, 2002
    6
    Swartz Creek, MI
    Oh...ok, the flywheel. Yeah, that comes with it. Now I've heard about them overheating, I have a 84 Chevy 3/4 ton. The grille, core support, and radiator have been swapped in from an 89-91 Chevy Blazer, is that radiator going to have sufficient cooling power?
  7. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    See if its a three or four core. Four your fine. Three, you might be fine. Might just have to run it and find out.
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've got a 400 small block in my 76 Blazer. Great motor, no complaints other then it's a small block and not that big block RamJet 502 I've been drueling over !!!! My 400 has just under 80,000 miles on it and is running strong. /forums/images/graemlins/k5.gif
  9. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    besides headers and exhaust I have a bone stock 400 and I love it. I have a 3 row radiator and haven't had a problem as long as you keep fluid in it.
  10. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I run a stroked 400 at 9.5 c/r with a 4 core radiator. Good torque and lots of grunt power. I'm running the stock 350 small valve heads with a pocket port and drilled the steam holes for the 400 block. In fact I'm running almost all the 350 external components other than the long block, flexplate and balancer. The engine will run hotter than normal with extended high load high rpm use (pulling a heavy trailer up a steep grade rev'd high in a low gear), other than that it always runs around the thermastat setting. Great compromise to running the heavier big block.
  11. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I agree. The only reason I went BB is because I fried the 400.
  12. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Turn it into a 377 destroker and really turn some RPMs. From what tinkering I've done on these programs, a 350 seems to put out more power per cubes than a 400. 400s' torque is insane though, it'll do in a 383.
    The only thing that will be a pain is getting it work with bigger rods. The 400s used 5.56" long rod which creates a higher side load on the bores and wears them out faster. You can get them to run 5.7" rods with the appropriate pistons and a little clearancing on the rods. Then get a good radiator and you won't hear a peep. Oh, and maybe internal balanced stlye crank wouldn't hurt either. Every damn motor is expensive.
  13. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    400's kick a$$. I loved mine in my 74 jimmy on 38's. It had 4.10s and would fry the tires like there was no tomarrow. I never had an overheating problem with mine till the water pump went out. If you do build one post what you did and if you like it cause i wanna build another one.
  14. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I know there is a stroker kit for the 400 sbc, I just can't remember what it brings it up to. 400's have good torque to start with, but the stroker kit is suposta be even better yet.
  15. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    THe popular strokers for a 400 are 415, and 427. thats alot of cubes out of something that (relativly) small. Im going to be building a 406 (overbored) soon, just got it on the stand for dissasembly, so im pondering what route to take also, oh well, only time and my wallet will tell what she becomes. /forums/images/graemlins/grin.gif
  16. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    If you can, stay away from the 4 bolt 400 blocks. They are actually weaker. A good rad is a must. they run alot hotter.I would consider the destroke or long rod conversions. The rod angle is what kills these engines. Klien racing makes a 454 stroker for them. also, for the record, A FLEXPLATE is for automatics and a FLYWHEEL is for standard tranny's!!
  17. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    That's the one I was thinking of getting. The 415 stroker kit.
  18. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    If you decide to go with a 400 you will not regret it. I had a 3 row radiator in mine and it would heat up a little on long uphill runs, but I now have a 4 row radiator with a good fan and it never gets above 190 degrees, it usually runs about 160. I built mine about 6 months ago and it has been absolutely great, when me and my friends are out riding and someone gets stuck to the point where a truck with alot of nuts is needed who do you think they always look to ? /forums/images/graemlins/cool.gif
  19. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I'm puttin a 400 in my soon. Anyone have any leads on a place to find a manual flywheel for it in the Denver area?
    /forums/images/graemlins/1zhelp.gif
    Thanks.
    Marty---
