400 to 203 adapter.
Discussion in 'The Garage' started by mkinnunen, Sep 27, 2004.
  1. mkinnunen
    mkinnunen Registered Member
    Aug 29, 2003
    43
    Albuquerque
    It uses two gaskets and one seal anybody know the part numbers and where to find them, or should I use some form a gasket stuff?
    Thanks,
    Michael
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    the seal for the 203 is in the aluminum housing, not the cast adaptor. Your correct, it does however use a fiber gasket on each side, as well as o-ring under the heads of the bolts that holt the tranny to the adaptor.
  3. mkinnunen
    Aug 29, 2003
    43
    Albuquerque
    I see where the o-rings go under the bolt heads they are not there but I will get some. I'm talking about the other side under the six hole gasket, I dug out a seal.
    Michael
