400$ to spend...but on what ?
Discussion in 'The Garage' started by arik2, Apr 14, 2004.
  1. arik2
    arik2 Registered Member
    May 25, 2003
    9
    Hey all,
    My big question is what can I deliver back home (Israel) with a friend who's coming back from the states...
    Well, I got already an 86 K30,5.7 350, TH400HD, NP208, 37" tires, 4.56 R&P, F axle D60, R axle 14bolt FF with Detroit locker, holly carb etc.
    Since I will find a front locker here, I would like your suggestion regard things that will total weight below 10 pounds and with a 400$ budget.
    My rig isnt my daily driver and it used for rockcrawling.
    thanX 4 assisting.
  2. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    If you had 500 you could get a detroit. For $400 you can get a lockright and some used hubcaps.
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    It seems he has the locker situation covered. /forums/images/graemlins/wink.gif
    It's going to be tough to get some hardparts that are under 10 pounds....hmmmmm.... /forums/images/graemlins/thinking.gif
  4. arik2
    May 25, 2003
    9
    As BlazerGuy wrote, the front locker is not the issue...I got one down here.
    I believe that my friend can carry with him even 20 pounds...but still, I prefere it NOT to be too big or heavy...
    For now, on my mind there are two options, Fuel injection swap OR Ignition kit...but I would like to know if there are more options that i didnt thought about.
    /forums/images/graemlins/confused.gif
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Hey all,
    thanX 4 assisting.
    [/ QUOTE ] What do you have for mufflers ??? Kinda hard to beat the sound of Flowmasters. Maybe a MSD ignition box ??? /forums/images/graemlins/thinking.gif
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    A digital camera so you can take some pictures of your truck and post them here. /forums/images/graemlins/deal.gif /forums/images/graemlins/waytogo.gif
  7. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    35 spline outer stubs and hubs for your Dana 60 /forums/images/graemlins/waytogo.gif
    Maybe a tad over 10lbs but you would have money left over /forums/images/graemlins/woot.gif
  8. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    4 Bilstein 5150 shocks will be $398 at eshocks.com and should be around that weight /forums/images/graemlins/thumb.gif You can send the other $2 to me. /forums/images/graemlins/deal.gif /forums/images/graemlins/whistling.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    How about an NP 205. Not less than 10 lbs either but you'll have money left over. /forums/images/graemlins/thumb.gif
  10. detailer03
    detailer03 1/2 ton status
    Sep 23, 2003
    108
    Arizona
    Israel? what part. I have been there.
    You can send me a PM if you want.
  11. arik2
    May 25, 2003
    9
    heavy4x4, I got one...but since the body is kind of wreck, I prefere finishing with my flatbed...and then you will get some.
    FRIZZLEFRY, mine PU came with 10bolt up front and 14bolt SF on rear. this week i started installing a CUCV HD axles which mean beside FA D60 and RA 14boltFF, I also have the HD hubs etc. /forums/images/graemlins/wink.gif
    Z3PR, I thought (and still) about the MSD, but i'm looking for more options...and since there is some problems with the transportation regulations & laws /forums/images/graemlins/dunno.gif I'm not going to be noisy.
  12. arik2
    May 25, 2003
    9
    spearchucker, 4 now, im not planning to touch the suspantion because my plan it built up new flatbed which i dont know the weight off, and beside that, since I use for the meanwhile leafsprings, and 4 doing some rockcrawling (very slow driving), the shock are are not that mean (except their length) !
    if & when i will swap into 4 link suspantion with coil spring i will need to think about the shocks. Now it quite fine with a mixture of ES3000 (procomp) and the Rancho 9000.
    84_Chevy_K10, I can find here the 205 or the 203 in a better price (170$-350$).
  13. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    My birthdays soon, you can give 399.99 to me, and keep a penny for good luck /forums/images/graemlins/waytogo.gif
  14. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Throw it in a pot for a day when you can afford a winch
  15. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    How about an Art Carr Cable Gate Shifter (they are on sale for $199.99 down from $285) and a Reverse Manual Valve Body for that th400. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  16. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Hydro steering........ /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  17. arik2
    May 25, 2003
    9
    Where can I find the shifter sale ? though it happend to me more then once, it can be very usefull to switch to the appropriate gear...
    mudjunkie 82, the hydro steering sounds usefull too, even when my plans for the near future is staying with 37" tires but i'm pretty sure it does help the steering and im very familier with the inability to turn a tire that was wedged against a rock.
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Another huge benefit is that it will help take some of the stress off that area of the frame behind the steering box.
  19. arik2
    May 25, 2003
    9
    After making some checking, as I understood, I can do the stage 1 for upgrading my steering to a hydro boosted (hydro assist) because since I'm not planning to send my steering box from here (Israel) to the states and back. the stage 2 option cost 450$ as I understand...so its out of budget for the meanwhile.
    As for the shifter, I didnt found yet the 199$ deal but I have found some B&M shifter kits around the 170$, does anyone here have some experience with them ?
    10X
  20. TOMER
    TOMER Registered Member
    Sep 20, 2002
    38
    Israel
    Hey Arik,this is Tomer as known as jimmy in the israel site-jeepolog,My suggestion for you is to wait and save up some money for the ORD doubler....1000$ /forums/images/graemlins/thumb.gif
