400 trans upshift@5500 .easy fix?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chillywilly, Aug 25, 2002.
  1. chillywilly
    chillywilly Registered Member
    May 26, 2002
    70
    northern maine
    doing mud bogs here need a way to keep 400 trans in first.ty in advance!!!!!!
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    ummm. dont quite get the post, but if ya wanna keep it in first, put ur shifter in low 1. welcome to ck5
    NITRO
  3. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    I think some of the more advanced shift kits, Such as B&M's Transpack, have the modification to allow the tranny to stay in first as long as the shifter is there. My brother has my TH400 book, so I will check later to see if there are any Modifications listed there.
  4. rodzzilla
    953
    Grinnell, IA
    TH400's will automatically upshift from 1st even if the shifter is held there.
  5. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Rod is correct
  6. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    yep
    my old corvette was like that
    put the shifter in 1st and stomp the gas and at about 5500 rpm (60mph)
    it would bark the rear tires and shift to 2nd
  7. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I dunno, dumb guess...unhook the vacuum modulator. Might eliminate all upshifts.
  8. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    Your tranny is shifting on the govener. Dont disconect the vavume modulator. It will show the trany zero vacume, just like WOT. You will need to modify the govener. You can modify the weights and change springs. I think you want lighter. Some people use a govener from a corvet.
    If you realy want to control shifts how about a manual valvebody? /forums/images/icons/wink.gif
    Marc
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    You can modify the governor to raise the upshift points, but it will raise them under all driving conditions and all gear selector positions.
    It's gonna take valve body modifications to make it a manual/auto valve body. Call B&M or even Summit Racing. They should have something to help you out.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A shift kit will give you total control.
  11. Blue85
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    Some shift kits will give you full control. Some won't. You have to check. Some don't do anything more than firm up the shifts. Summit lists a Transgo automatic/manual kit for the 400 for about $75.
