400 transmission question????
Discussion in 'The Garage' started by blazindorito, Sep 17, 2006.
  1. blazindorito
    blazindorito 1/2 ton status
    Nov 25, 2003
    2,047
    Southern California
    I installed the transmission on my 83 k5. It was recently rebuilt. I filled it up with fluid and when I start the truck it leaks a lot of tranny oil from the top of the dipstick. It is not overfilled and was wondering what else may cause this? It does this everytime I start it but then stops after it's poured about 1/2 bottle of fluid. Thanks for your help!
  2. 85-m1028
    85-m1028 1/2 ton status
    Apr 26, 2005
    485
    costa mesa california
    did you rember to fill the converter with fluid before installing??
  3. blazindorito
    Nov 25, 2003
    2,047
    Southern California
    Yes. sir I did. It was filled before installing.
  4. t89blazer
    t89blazer 1/2 ton status Premium Member
    Jan 16, 2005
    677
    Jackson, MS
    Did you fill the trans with the engine running. The only way you get a true reading on the dipstick is if the engine is running.
  5. blazindorito
    Nov 25, 2003
    2,047
    Southern California
    Yes the engine was running for about 15-20 minutes. It has done this for about 6-8 times already. once for every different day. I have not droven it yet. Had to finish fixing the rear and other things but I would turn it on just to keep the battery from draining. Everytime I would start it up it would leak like crazy from the top of the dipstick.
  6. t89blazer
    Jan 16, 2005
    677
    Jackson, MS
    Do you remember how many quarts of fluid you put in the trans when you filled it up? If you filled the trans with the engine running I would check the breather on top of the trans to make sure that it is now clogged.
  7. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    Check the vent. And maybe try shifting through all the gears, to get any trapped air pockets out.
    Good luck
