402 BBC really is a 454!
Discussion in 'The Garage' started by madmike, Mar 18, 2003.
  1. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    OK, turns out what I thought was a 402 engine, really is a 454 block (casting no 3999289). Evidently maybe the factory ran out of 396 or 402 blocks, grabbed this 454 block, and only machined it for 402 use. I had the cylinder wall thickness sonic tested, and there is plenty of meat there to support a 454's 4.25" bore. Since it really is a 454 block, there is also enough to support a 0.030 and 0.060 overbore later if needed.
    If I can find a reasonably priced 4.00" stroke crank, I think I'll go ahead and reassemble it as a genuine 454! /forums/images/graemlins/cool.gif
    Who out there has a 454 crank (cast or forged) in good shape cheap?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    If you use your 396/402 crank shaft and bore it for the 454 pistons, you'll have a 427 if memmory serves me correct. Now being able to say it's a 427 would be very kewl in my honest opinion. /forums/images/graemlins/thumb.gif
  3. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    Well good for you! /forums/images/graemlins/thumb.gif That's the better kind of surprise....my engine was supposed to be a 427, and ended up only being a 396 when I tore it down! /forums/images/graemlins/mad.gif
    Oh well, at least NOW I know it's built right and that it will last.....the P.O. of my truck was kind of a knucklehead, and probably got tricked by the engine shop that built the motor for him.
    ......of course I got tricked too, so I guess there's TWO knuckleheads in my story!..... /forums/images/graemlins/rotfl.gif
  4. madmike
    Jan 23, 2002
    496
    ohio
    Z3PR-Your memory is correct, and its possible I'll go the 427 route, but I'm down this far, so I'm gonna go big as I can at this point!
    Greg72-That's a bummer /forums/images/graemlins/tongue.gif, sucks to downsize when ya think you're going big. Glad ya got it built right, that's what I'm shooting for too! /forums/images/graemlins/grin.gif
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Note that if you go to a 454 crank, you go from internal to external balance, so you have to swap the flywheel/flexplate and the damper also.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, thats right...that will make it a 427. /forums/images/graemlins/thumb.gif
    Now if he had a 402 block and used a 454 crank, that would make the motor a 435 cubic inch. /forums/images/graemlins/thumb.gif
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    [/ QUOTE ]A 402 block with a 454 crank would make a 427 not a 435.
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    I checked my references and what I quoted was for a 402 block with a .030 overbore, or rather a 396 block bored .060 over, to get the 435 cubic inch.
    The references did list a standard 402 block, or a .030 overbore 396 block, and a 454 crank to be a 428 cubic inch rather than a 427. /forums/images/graemlins/thumb.gif
  9. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    [/ QUOTE ]OK Wes, if we are going to argue size to the exact then lets BE EXACT. A STD. bore 402 block with a 454 crank is 427.44297 CI. A 402 block .030" over with a 454 crank is 433.68445 CI. /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/thumb.gif
  10. madmike
    Jan 23, 2002
    496
    ohio
    Blazer1970-you are correct, going from internal to external balance, I'm already taking that into account parts-wise.
    thatK30guy & 4X4High-I'm interested in building a stroker motor and maintaining a stock 4.25" bore (to save the block for future use). Flatlander racing and speed-o-motive have kits I'm gonna research a little today.
    4.25x4.25x4.25x0.7854x8=482ci! /forums/images/graemlins/cool.gif
  11. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    If your gonna lok for a crank, id look for a 4.25" stroke crank to bump the displacement up a bit more, like about 483 cubes/forums/images/graemlins/thumb.gif
  12. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Check this site out. wish I has some money.....
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif @ "if we are going to argue to the exact....." /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  14. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    That's Close enough is'nt it? Nitpick, Nitpick, Nitpick!
    J/K /forums/images/graemlins/blush.gif
  15. Emmettology 101
    May 9, 2000
    8,126
    FL
    *using the Jedi mind trick*
    I think you would rather have a efi LT1!! I'll trade ya! /forums/images/graemlins/wink.gif
    I am going to have to start hangin aroudn you and Jerry, you guys are finding some sweet-a$$ deals!
  16. madmike
    Jan 23, 2002
    496
    ohio
    Jerry is the real deal finder! I haven't come across any myself lately, cuz I'm broke and so absorbed in what I already have! /forums/images/graemlins/laugh.gif Got a ton of stuff, just need the funds to start putting it together.
    I did place an order on the parts for my 489 bbc the other day, I can't wait for the boxes to start showing up! /forums/images/graemlins/grin.gif
  17. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    If you are gonna go big, since you already have to replce crank, I would go the 4.25 stroker. They have come way down in prices and can build an awesome motor. They can weld and remachine a stock crank to get just about any stroke you want!!
  18. madmike
    Jan 23, 2002
    496
    ohio
    Dude- I did! /forums/images/graemlins/cool.gif I ordered 4.25" stroker crank kit from speed-o-motive. With a 0.030" overbore, its gonna be a 489ci! /forums/images/graemlins/grin.gif
  19. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    /forums/images/graemlins/eek.gif 602ci?! omg...I need it....If only I had the money...
    hmmm...
    Anyone need a kidney? Mine just went up for sale! /forums/images/graemlins/rotfl.gif
  20. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    [/ QUOTE ]I hope you're taking into account the nessecity to rebuild your transmission to withstand the now mad torque this thing is going to have now.... /forums/images/graemlins/grin.gif
    I'da gone 427: the shorter stroke allows you to rev the higher, granted this isn't going to be much a problem on a truck, unless you throw a tripplestacked doubler at the project...
    -Rich
    PS, Big Blocks rule, and make me happy.
