40's on 10inches of lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFlap, Jan 29, 2003.
  1. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    40\'s on 10inches of lift
    I have looked at all of the charts that tell what tires you can fit with how much lift, but I would like some first hand experience.
    On my 89 Blazer I have a 2" body and I am going to do about 8" of suspension lift and I have the 1 ton gear to swap in too.
    Can I fit 39.5" swampers without cutting fenders? The blazer is rust free and in good shape and I dont want to hack it up. I will be doing mostly mud and trails, no major rocks or anything. I have 6" tuff country ez ride springs for the front and I am gonna do longer shackles and maybe zero rates. I am gonna put f150 springs and blocks in the rear. So it should be fairly flexy, but I don't know how much I will be flexing it.
    I am fairly sure that the 39.5" will fit with normal driving and wheeling, right? But if I get real crossed up will I be rearranging my sheetmetal?
    Trey
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: 40\'s on 10inches of lift
    <font color="green"> It should flex pretty well, and that's what's going to cause rubbing. I'd guss that you're going to have to at least knock the rear corners off of the front fenders. </font color>
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] I think you'll have really bad axle warp. The f150 springs are way soft.
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    my buddy did 13" to clear his 40's
    he had 9" and 38's
    10" springs and 3" body.
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You might have to move the axle forward. This made a big difference in clearance on mine. I have 6" and 3" body but I did cut the fenders quite a bit. But it all clears now in the rocks.
  6. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    Thanks.
    Sounds like I am either gonna have to cut or go to 38's.
    I was thinking about moving the front axle forward, but will this help only if I cut the fenders?
    Is axle wrap going to be that much of a problem?
    Thanks again,
    TRey
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    good grief, cut them fenders!!! if you're worried about the end result looking "pretty" then take it to a body shop and have them do it. Pretty pointless in a real wheelin rig... only a matter of time before it gets bashed by a rock anyway... but to each their own! /forums/images/graemlins/grin.gif At any rate, trimming the fenders saves a LOT of headaches and $$$ since you can use less lift. Keeps the rig nice and flexy too, most 12" springs are stiff-tastic.
    j
  8. 98sub454
    98sub454 Registered Member
    Jul 18, 2002
    74
    La Habra, CA
    i just bought a 10" today and am planning on running 40s, ill let you know how it goes.
    how wide a tire are you planning on using?
