410hp / 425 ft-lb torque - need the $$ - Lower Price
Discussion in 'General Parts for Sale' started by Topdown, Nov 22, 2003.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Holley 670 Street avenger carb, tuned to the engine
    Edelbrock air-gap intake
    Trick flow angle plug heads 2.02/160 - Kick Ass!
    - comes with spark plugs
    1.6 ratio aluminum full roller-rockers - roller tips and fulcrum
    Comp Cams Magnum push rods
    hardened steel guide plates
    double roller Comp Cams timing set
    Comp Cams xe268 extreme energy cam - nice lope, still gives lots of vacuum for brakes and whatnot
    4-bolt main block bored .030 over
    Keith Black Hypereutectic(sp) pistons with chromoly plasma-cut rings
    GM "pink" rods
    SCAT forged crank shaft
    7-quart moroso oil pan with high-volume pickup & windage
    stock volume cast long neck water pump
    Needs a flex-plate, starter and a fuel pump
    dyno'd at 410hp and 425tq /forums/images/graemlins/eek.gif /forums/images/graemlins/grin.gif
    needless to say, it SCREAMS...
    For sale for 3000.00 (cost of the parts in it)
  2. Topdown
    Nov 26, 2002
    2,598
  3. Topdown
    Nov 26, 2002
    2,598
