427
Discussion in 'The Garage' started by 86chevybanshee, Nov 23, 2004.
  1. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i can get my hands on a 427 for 100$, it needs rings and thats about it. how would this engine do in a truck, i heard they are more torquier than a 454. /forums/images/graemlins/dunno.gif
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    if its a passenger car 427 buy it, sell it, and reap a tidy profit.
    but I'm guessing its a 427 td.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    When equipped simmilar , the larger engine will make more torque . What the 427 has going for it is it will rev higher if the valetrain is quality and the induction/exhaust is equipped to handle it . But hell a BB for 100 is good anyday /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  4. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    i think its out of a bucket truck or something
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Regardless , a re-ring kit , some rebuilt heads , a nice intake/carb/cam/headers , and your rock n rolling . I bet you can do it for cheap if you don't need machine work
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    A 454 has more torque than a 427 due to the longer stroke on the 454, they share the same bore. I think it would be a good mud running motor.
  7. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    If it is out of a bucket truck then it is probably a Tall Deck 427... you can make these into a 600 cube monster. In stock form they don't like high RPM's very much, pistons have an extra ring, and standard big blocks stuff (most brackets, intake, etc...) will not work on them. Lots of drag racers and boat racers build the Tall Decks... but they put alot of $$ in them.
    Also, make sure it is NOT a 366... they look like a 427 but are a sh!t motor, and not good for anything.
  8. elacruze
    elacruze 1/2 ton status
    Dec 23, 2003
    121
    SE Michigan
    I have a factory MercCruiser 500 which is a Tall Deck 427 with a 1/2" stroker crank. It's the monster you'd expect with those specs, but the strange thing is the fuel mileage-it gets much better economy than a crate carbureted 502.
    The biggest trouble with them is the shortage of intake manifold selections. Mine has an old Tarantula with spacer plates.
    $100 is a steal.
  9. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    my 465 should fit behind it right?, also will i have to swap motor mounts or anything?
    thanks
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    thanks
    All Chevy V8s share motor mounts and bellhousing pattern.
  11. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Just curious how you've figured out you would get over 600 cubes!? What would the bore x stroke be?
    I've spent some time trying to figure that out before.. .100" over and a 4.5" stroker crank would yeild 535 cubic inches.? I think its possible to get it to 572, but how bout 600+ cid?
  12. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I think you may have to rock the block to get to 600, but I know it can be done because lots of guys at the drag strip do it. I believe it is someplace around 4.6" bore and 4.6" stroke and you get pretty close to 620 cubes. It is definetly not cheap to do, and does not make a streetable motor... but it can be done.
