428 Pontiac
Discussion in '1936-Present Suburban' started by nevercomplete, Jan 25, 2003.
  1. nevercomplete
    nevercomplete 1/2 ton status
    Dec 25, 2001
    309
    Beaufort, South Carolina
    Here's the deal. I've been offered a 428 pontiac engine. I have always wanted to make my truck different, not the same thing everyone else has. I'm want to put this engine in my suburban. I know I need an adaptor plate to bolt the engine to my tranny, but what else do I need? Are the engine mounts the same? What am I missing? Thanks for your help.
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Mounts are different. Brackets are different. It will take some work to get it in there. You could give it to me though /forums/images/graemlins/wink.gif
    Dan /forums/images/graemlins/burb.gif
  3. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    You don't need an adapter for the trans. Just use the BOP trans and have a 4wd output shaft installed. I know a guy who took the 455 out of his T/A and had it in is 4x4.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The adapter only costs $65. That seems a whole lot cheaper and easier than tracking down a BOP tranny and then having to strip both trannies down to the bare case to swap the output shaft. /forums/images/graemlins/shocked.gif
  5. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    dude go for it it's alll about being different to me. /forums/images/graemlins/thumb.gif /forums/images/graemlins/pimp1.gif /forums/images/graemlins/burb.gif
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Here's the adapter that you need: http://store.summitracing.com/partdetail.asp?part=27457 The price has also dropped! It's only $54.95 now. /forums/images/graemlins/thumb.gif
    It looks pretty simple too. /forums/images/graemlins/cool.gif
    Just figure out how to fab up the engine mounts, then get a 454 radiator and you should be good to go. /forums/images/graemlins/cool.gif Oh yeah, do some measuring first. I don't know how wide the 428 is, but some of the BOP motors are really wide (Olds 455 comes to mind). It might require some massaging of the firewall and/or the A/C box, if the truck has A/C.
  7. nevercomplete
    Dec 25, 2001
    309
    Well, the guy running it now has it in his '79 Blazer. He is giving me the tranny adaptor so I'm covered there. Thanks for the help.
    Jon
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Why didn't ya say that in the first place? /forums/images/graemlins/wink.gif There isn't any difference between installing it in a Blazer and installing it in a Sub. Just get his engine mounts too and you're all set. /forums/images/graemlins/thumb.gif
  9. nevercomplete
    Dec 25, 2001
    309
    Well, he didn't put it in there so he doesn't know what all was done to make it fit, and he will have taken the engine out and have replaced it before I get a chance to pick it up, so I won't have the convience of doing the swap from one truck to the other. I just want to be prepared and not have any surprises.
    Jon
  10. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    If you dont want any surprises, then like I mentioned before, get all the brackets. If it doesnt have the pontiac brackets, then you need to buy them from someone like classic industries. Also the pulleys are differnt. So your best bet is to get a complete motor with accs. Or is you want to spend the $ March pullies has a serpintine setup for $1100 if you have A/C, 900 without.
  11. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Just make sure that he saves the tranny adapter and whatever mounts are holding the engine in place. Then the install should go pretty smooth! /forums/images/graemlins/thumb.gif
  12. nevercomplete
    Dec 25, 2001
    309
    It comes with all the brackets.
  13. holyjohnson
    holyjohnson Registered Member
    Nov 22, 2001
    94
    the fringe of insanity (only on mondays)
    sounds like a good idea.
    different is good!
    more cubic inchs!
    goodluck
  14. nevercomplete
    Dec 25, 2001
    309
    I just talked to the guy I'm getting the engine from and he says the engine bolts right up to his th350, no adaptor. Whats the deal, I thought a pontiac engine wouldn't bolt up to a chevy tanny.
  15. 84K5BD
    84K5BD 1/2 ton status
    May 19, 2001
    302
    arlington, mass
    your right they will not bolt up without an adapter, how are you making out with the swap? is it finished?
  16. nevercomplete
    Dec 25, 2001
    309
    I haven't even started. I'm still stuck overseas.
