42's vs 44's
Discussion in 'The Garage' started by BranndonC, Feb 3, 2004.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    42\'s vs 44\'s
    i've noticed more people seem to run 42's than 44's. Is there a reason to this? i mean cost at that point isnt a huge difference, so there must be another reason? maybe brakeage?
    anyone care to fill me in? /forums/images/graemlins/confused.gif
  2. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    Re: 42\'s vs 44\'s
    I considered 44's carefully before decided to run 42's. The reason was and is the bigger rubber needs too much space with only 3" of lift. It did not seem to be worth it in my opinion.
  3. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Re: 42\'s vs 44\'s
    The 44's are alot wider. In my case, and alot of peoples cases, the width is harder to fit than the height since when turning the tire smacks the frame...
  4. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    Re: 42\'s vs 44\'s
    never thought about the width hitting the frame, thats a good point. thanks /forums/images/graemlins/thumb.gif
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Re: 42\'s vs 44\'s
    More lift will fix the frame problem. /forums/images/graemlins/thumb.gif
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    Re: 42\'s vs 44\'s
    i'm not lifting it enough to where the frame is 44 inches above the ground /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Re: 42\'s vs 44\'s
    [/ QUOTE ] It doesn't takr 44" of lift, just enough to clear the tires a little more when turning, get the frame above the widest part of the tire.
  8. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Re: 42\'s vs 44\'s
    lift = bad
    And what happens when you stuff the tire? It goes back up and hits the frame. /forums/images/graemlins/rolleyes.gif
  9. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Re: 42\'s vs 44\'s
    You can't stuff 44's anyway unless you have hacked fenders.
    Less backspacing might help... /forums/images/graemlins/dunno.gif
  10. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Re: 42\'s vs 44\'s
    Less backspacing will make the tires turn in a large arc and just slam them into the firewall. Yeah, hacking fenders = good, lift = bad.
  11. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Re: 42\'s vs 44\'s
    Less backspacing would help if there was just a little bit of extra lift. Just enough to keep them from swinging into the firewall.
    enough lift=good
  12. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Re: 42\'s vs 44\'s
    i run 40's and it is danereously close to all of it. no idea how you'd run 42's without serious firewall/axle movement and/or modification
  13. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Re: 42\'s vs 44\'s
    Don't really see how the extra inch of lift you get out of the 44's is worth the extra rotating mass you have to move and I don't see the extra width being too helpfull when you're trying to fit a fullsize through the rocks. It might be worth it for the mud runners.
  14. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Re: 42\'s vs 44\'s
    There's a pretty big difference between the 42x15 and 44x18 Swamper. As mentioned the extra 3" of width seems to be more of an issue than the extra 2" of height.
    Ironically, most of the fullsize and hybrid guys in our club are going smaller. They've been running 39.5's to 42's for years (they did a lot of mud) and are finding that the skinnier 37's and 38's work better on the trails around here.......lot's of tight wooded areas. One guy even went from a pickup with 1-tons and 40's to an S-10 hybrid with 33's and D44/12-bolt. He hasn't had his "big" truck on the trail since he got the hybrid done.
  15. 73k5tony510
    73k5tony510 Registered Member
    Sep 25, 2002
    97
    Fremont,Ca
    Re: 42\'s vs 44\'s
    i dont seem to have anny problems with my 44s hitting my body or frame with 6 inches of lift /forums/images/graemlins/dunno.gif /forums/images/graemlins/thumb.gif
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Re: 42\'s vs 44\'s
    Yeah, I was thinking the same thing, no problems here running 42s with 4" of lift. /forums/images/graemlins/smirk.gif /forums/images/graemlins/whistling.gif
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: 42\'s vs 44\'s
    No body for them to hit. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
    I'm sure weight is a factor on the 42s decision too. A 44" Swamper is much heavier which puts more stress on the Dana 60 front.
    Even a 35 spline '60 isn't bulletproof. My friend managed to break his with 44s.
  18. 73k5tony510
    Sep 25, 2002
    97
    Fremont,Ca
    Re: 42\'s vs 44\'s
    its not the 44 alone breaking the 60.it has to do with how you drive it also.im sure i could bake a stub or u joint on a 60 with 36s.
  19. dustinellis
    dustinellis Registered Member
    Oct 30, 2003
    31
    south texas
    Re: 42\'s vs 44\'s
    rock guys say lift is bad mud guys want it sky high im somewhere in the middle a mud truck that can crawl,go 44"s that what i want when my 39"s are gone and thats not far off for a throttle jockey like myself.
  20. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Re: 42\'s vs 44\'s
    [/ QUOTE ] Thats the class I fall into... /forums/images/graemlins/woot.gif
