4340 outers
Discussion in 'The Garage' started by chiefheaphy, Apr 16, 2007.
  1. chiefheaphy
    chiefheaphy 1/2 ton status
    Mar 13, 2007
    632
    East MASS
    I got 35 spline outers on the way. Stupid question, but I've just never done it before. How do you get the damn u-joint apart. Those little bitches are tough.
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    someone posted this same thing last week, u got to beat them into submission, or press them out. try searching for more details.
  3. gmcjimmy4x4
    gmcjimmy4x4 1/2 ton status
    May 6, 2005
    132
    Sacramento, CA
    Ive heard heating them alittle with a torch may help, but you will still have to beat them out. You can also call a local machine shop, they will press them out for you with ease. Or go to harbor freight and buy a shop press for about $100. Youd be surprised how often you can put it to use.
  4. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    BFH or a shop press works wonders . Becareful with the BFH so not to deform the ears on the shafts . Tap on the down side of the ear heading towards the shaft.
    Tom
  5. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    Press
    6-ton press at Harbor Freight for $75 that should be more than enough force right? Even though I know the guy at the machine shop he still needs to make a living to. For what he would probably charge to remove and then later reinstall the joints I might as well invest in the press.
  6. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Have you removed the clips?
    -Harrison
  7. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    clips
    I cant find or get to the clips. Are they under the cap in the same place as driveshaft u-joints or are they on the underside?
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Most likely a 4340 shaft is heat treated. Getting anywhere near one with a torch will destroy most of it's strength.
    Clips are sometimes on the inside of the cup rather than the outside.
  9. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    Yeah, DON'T use a torch.
    Presses can bend the yokes on shafts and ruin them. Using impact (hammer and punch) keeps the yoke from bending and is the right way to do it, IMO.
