44-60F ID on front axle?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BAMBAMN, Apr 8, 2002.
  1. BAMBAMN
    BAMBAMN Registered Member
    Mar 7, 2002
    10
    Idaho Springs, CO
    This is stamped into front axle from a truck I bought for parts. It looks like a 44 on steroids. Never seen hubs that large on a 44 but axle tubes are the same as a 44. What exactly is this?
  2. lt1yj
    lt1yj 1/2 ton status
    Oct 7, 2001
    101
    Near Chicago, IL
    Post a pic.
    What year is it from?
    The king pin 60's have 4 bolts on the steering arm in a rectangular pattern. They also have 4 bolt covers where the ball joints would be on a 44.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    It is probably a D44 with external hubs. The external hubs are rather large. They came on earlier D44's. Pre-76 I think. Not real sure on the exact years. If the tube is the same size as a D44 and it has big hubs, the external hub D44 would be my guess.
  4. BAMBAMN
    Mar 7, 2002
    10
    Idaho Springs, CO
    The truck is a 73 1 ton single axle.
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    They didn't actually make a 1 ton 4x4 until 77 from what I understand. That is when they came out with the D60.
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Yup, no such thing as a '73 one ton 4X4, single or dual.
  7. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    yeah, Dana 44 with external hubs.
  8. Blazer1970
    1,600
    Old Mission, MI
    I thought GM quit using external hubs in '68 or so? Maybe a Dodge axle?
  9. BAMBAMN
    Mar 7, 2002
    10
    Idaho Springs, CO
    well I have proof of a 1 ton in 73. All this info is on tag in door jam.
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    It might be a 1ton, but it probably doesn't have a D60. It is probably a D44 HD. There are ways to check if it is a D60 or not, they may be listed above. If not people here know how to tell.
  11. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    D44 HD - I have the same exact axle out of a 76 K20 in my truck
  12. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Any pics of this tag?
  13. BAMBAMN
    Mar 7, 2002
    10
    Idaho Springs, CO
    so if it is a HD44 what does the -60F mean after the 44?? And what exactly makes a 44HD different from a regular 44?
  14. ca89blazer
    ca89blazer Registered Member
    Mar 2, 2002
    9
    Redding Ca
    44's have 4 u bolts and 60's have 3 u bolts and two bolts that thread into the pumpkin housing.
  15. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    No idea what the axle is...but a 60 has four bolts in a square (rectangle) pattern holding the steering arm on (even the closed knuckle versions but then so do 70's) a 44 has three bolts. If it is an original part from a '73 Chevy it is not a Dana 60.
