44s contact frame or springs?
Discussion in 'The Garage' started by four_by_ken, Sep 13, 2004.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Do I have to worry about my 44s hitting the springs or the frame? I assume I do, but how much?
    I run a Dana 60 up front, and there is only a little backspacing, cause I had to grind the calipers a lot to make the 15 inch rims fit.
    I want the tires to tuck under as much as possible, to help me fit and follow those damn little jeeps.
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I dont think they will hit the frame or springs, but maybe the firewall
  3. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Steering box, firewall, radiator support, springs. /forums/images/graemlins/waytogo.gif Fenders too if you aren't able to cut enough. You might hit less if you run more than 7" of lift though (that's what I got) /forums/images/graemlins/dunno.gif
  4. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    I know I am gunna hit the firewall. I will deal with it until I can get the axle moved forward over the winter.
    Forgot about the radiator support. Going ot have to figure that out.
    How will I hit the steering box? It is inside the frame.
    I am worried about the spprings with the offset I have.
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    The steeringing box is on the outside of the frame.
