44's ON A BLAZER?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BIGDEAL, Apr 17, 2001.
  1. BIGDEAL
    BIGDEAL Registered Member
    Apr 16, 2001
    27
    Waycross GA
    44\'s ON A BLAZER?
    MY BOSS WANTS TO MAKE A BOGGING TRUCK (BLAZER) WITH 44 BOGGERS. WHAT IS THE BEST WAY TO FIT THEM?
    8" SPRINGS/3" BODY/CUT FINDERS? THATS ALL I CAN COME UP WITH. 12" IS TO MUCH ON THE PINION ANGEL WITH OUT BIG TIME MOD'S (RIGHT?)
  2. LittleJimmy
    LittleJimmy 1/2 ton status
    Feb 16, 2001
    220
    Channahon IL
    Re: 44\'s ON A BLAZER?
    If you have a stock 10 bolt axle you might not want to go that big. You could have some real problems witht the axle shaft breaking. Or you could go with crome ally axle shaft's and regear the rear axle. Or you could do what i am going and find a 14 bolt which would be no problem. And I will probably run 40's or maybe bigger I don't no got to have $$$$.
  3. Re: 44\'s ON A BLAZER?
    The axle part is taken care of. He just needs to know about the lift. It will also run a 454
  4. flcpl4fn
    flcpl4fn 1/2 ton status
    Jan 9, 2001
    194
    Florida
    As far as the lift goes, a friend of mine has a 10" suspension lift and 3" body lift and he has 44 boggers on his truck. he doesn't have any problem with clearance or the drive shalt angle.
    '85 Jimmy in Jax, Fl
  5. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    This Blazer may show up in your neck of the woods. Hilliard FLA.
    79 Blazer 6"lift 35's locked/4:56 <A target="_blank" HREF=http://www.keith.coloradok5.com>http://www.keith.coloradok5.com</A>
  6. flcpl4fn
    Jan 9, 2001
    194
    Florida
    cool, i'm hoping to go there in the next couple of weeks
  7. keith
    1,158
    La Fayette, GA
    They run there a good bit. You can also ride up to Waycross and go to the one there. Lots of guys come from JAcksonville. There is also one in Douglas and one in Folkston.
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    There was a guy around here running a 3" body lift ad majorly cut fenders with 44's.... Look nasty and I wouldn't recomend it.
    Mike - <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>[​IMG]
  9. flcpl4fn
    Jan 9, 2001
    194
    Florida
    I will be in Hilliard this weekend. Well you be there?
  10. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    I ran 44" boggers on a Blazer with an 9" suspension lift, 3" body lift and cut fenders. Had no problems for most of the season till I hit a hole realhard and bashed in the drivers side fender in about 3 inches.
    Even at a 9" suspnesion lift we had to modify the drive angles for the front shaft. Went through 7 different front shaft till we got the right combo.,
    This year we have gone 12" suspension lift
    <A target="_blank" HREF=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </A>
    <P ID="edit"><FONT SIZE=-1>Edited by white_knight on 04/17/01 11:45 AM (server time).</FONT></P>
  11. keith
    1,158
    La Fayette, GA
    top
