45 mph vibration
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rowdysr, Nov 26, 2000.
  1. Rowdysr
    Rowdysr Registered Member
    Nov 18, 2000
    20
    Whidbey Island, WA.
    Help! Front end vibration that increases upon acceleration. I changed the harmonic balancer and motor mounts. Any suggestions?
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Front U-joint? CV joint? Loose bearings? Does it feel like it's engine or suspension related? It could be something as simple as a loose accessory bracket, too. It could also be a bad tire.......Do you have any more info?
  3. Rowdysr
    Nov 18, 2000
    20
    Whidbey Island, WA.
    changed the u-joints - new power steering pump and pulley. everything is tight. No visual problem.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Do you have automatic hubs? I had a vibration from the front of my 89. Also had clicks and clunks. Got rid of the auto hubs. Put in manuals. And presto chango no more vibration or noise. Seems I had one hub that would engage and disengage whenever it felt like it.
  5. EDGE
    EDGE Registered Member
    Aug 12, 2000
    42
    virginia beach , va
    You might as well just sell it to someone like me.I need a good parts blazer!
  6. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Check the balance on your tires.
    Luke
  7. FLWIV440
    FLWIV440 Registered Member
    Nov 21, 2000
    32
    IF THE VIBRATION IS ON ACCEL. ONLY YOU MIGHT WANT TO CHECK TO SEE IF YOU ARE MISSING TEETH ON YOUR REAR DIFFERENTIAL. AFTER CHECKING YOUR U-JOINTS. HAD THE SAME PROBLEM ON AN 85. tire balance really has nothing to do with it . tire balance is mostly for speeds over 35 mph.
  8. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple>I had a 79 Chevy pickup once that vibrated bad at higher speeds, I found out it was a front seal that was bad for quite some time so crud was getting in there and my short shaft in the axle had a big worn groove in it. I replaced it along with new bearings, races and seals and I could fly without vibration ever again!</font color=purple>
    <font color=purple>L8r,
    .Riz.<font color=purple>
  9. Rowdysr
    Nov 18, 2000
    20
    Whidbey Island, WA.
    Thanks for all the info!
