454+3.73+35" Good idea?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer79, Apr 26, 2001.
  1. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    454+3.73+35\" Good idea?
    OK guys, I need your opinion on this.
    My original plan was to go with 3.73 gears with 33" tires, but since I now have a 454 (not installed yet), will everything hold up if I go with 35" tires once I install my 454 and 3.73 gears? Or am I looking to break something?
    I used an online calculator and the rpms would still be about 200rpm higher than my current 3.07+31" setup. What do you think?
    All opinions accepted.
    PS It's a 12 bolt rear and a 10bolt front.
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]<P ID="edit"><FONT SIZE=-1>Edited by Blazer79 on 04/26/01 06:25 PM (server time).</FONT></P>
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Re: 454+3.73+35\" Good idea?
    I would have a hard time believing the axels are going to hold up to the torque of the big block. If you are really going to push this truck, I would go to bigger axels. the 454 should have enough torque, but 4.10 would still be better.
    your right. I don't understand the jeep thing!
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I agree w/ bablazer... need the bigger pigs under the truck... then would be easy to go 4.10's. I'm going to 4.10's w/ my 35's after a lot of thinking and researching... 3.73's will be a little weak for acceleration... but better on the freeway
    1987 Chevy K5 Blazer- 350 TBI
  4. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    I had that exact combo. I blew u-joints and everything else regularly. I know am the proud owner of a 14 bolt rear and don't break a thing.
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
  5. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    I had the same exact combo in my suburban a few years back. I took it to a mud drag and got 2nd place out of about 40 trucks. Mildly built 454's like low rpm's. I think you will like it. I would at least try it before you switch out the gears. As for reliability, be smart with the gas pedal and you shouldn't have a problem.
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Not to mention your tranny will be getting some asskicking in the middle of that whole mix.
    Will work for beer, parts and tools.
    90-350TBI-TCI700-241-33"-10/12 bolt w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Dont lose hope. This set up can and will work as long as you do one thing: DRIVE SENSIBLY!!! [​IMG]
