454 350 swap
Discussion in 'The Garage' started by CTBlaz45, Jun 16, 2004.
  1. CTBlaz45
    CTBlaz45 Registered Member
    May 16, 2003
    50
    Killingworth CT
    Does the 454 and the small block have the same bolt pattern. I am assuming not but figured I would ask.
  2. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Which bolt pattern? The tranmission will bolt to the big or small block. The starter and distributor (if both motors are HEI) will be the same also. The firing order is the same.
  3. CTBlaz45
    May 16, 2003
    50
    Killingworth CT
    Cool so if I get a 454 I can bolt it to my existing turbo 400?
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
  5. ugly_blazer
    Apr 12, 2004
    1,214
    The motor mount location is the same also.
  6. CTBlaz45
    May 16, 2003
    50
    Killingworth CT
    Well That just calls for an evil laugh!
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That isn't a Ford you're swapping engines in. No need to figure out what city your engine is named after or change everything just for an engine swap.
  8. CTBlaz45
    May 16, 2003
    50
    Killingworth CT
    Some times Iwish it was I Have 3 ford trannys 2 transfer cases and a 460. I dont have many extra gm stuff
