454 BBC TBI on SBC
Discussion in 'The Garage' started by 4X4HIGH, Jul 22, 2004.
  1. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    What are people doing about the TV cable hook-up and the cruise control cable on the TBI? I have a BBC TBI but there is only one provision for hooking up the throttle cable, nothing for anything else. Also I thought I seen somewhere there is an electrical wire adapter for the TPS switch but what about the IAC?
    Ok, I just found the adapter wiring and its for the IAC not the TPS, (turbo city #975-325 = $19.95) I also discovered that GM used 3 different styles of TPS switches of which 2 are interchangable.
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Duno what this thing looks like, but can't you make a bracket or something to work?
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I am thinking about taking the bracket piece off of the throttle shaft and replacing it with one I have off a spare SBC TBI. The other thought is to just swap out the whole shaft depending on how the throttle blades attach to the shaft. As long as the throttle blades don't go through the shaft then I can just enlarge the openning and go that way.
