454 build, tell me what you think.
Discussion in 'The Garage' started by jk3078, Mar 25, 2007.
  1. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    454,.030 over mark IV block
    eagle rotating assy. with forged rods and hyper. Fedral Mogul, 9.5:1 pistons
    fully balanced
    stock heads, #346236, oval port, open chamber 120cc, 225, 116 ports
    comp cams, duration 254/262, lift .505/.505
    comp cams double roller timing set
    holly street dominatior intake
    holly 770cfm truck avenger
    stock hei, msd module with rev limiter
    clevite 77 rod and main bearings
    stock manifolds with 2.5'' duals and flow masters
    I am looking to get nice power off idle and up while still being able to spin some rpms. What would be a reasonable rpm limit to set on this motor with out blowing chunks? What do you think the hp/torque out put of this set up might be (ballpark)? This build is right at the edge of my budget but I am all ears if anyone has suggestions, thanks J.
  2. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    If your budget allows, I would also install a good set of headers. Hookers would be my choice.
  3. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    If you are spinning it, I would definitely get headers, and safely spin it to 6000 redline. 2 bolt mains I presume? If so, I would put main studs in it, and ARP rodbolts.
  4. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    Headers are out at this point for cost and fitment reasons. The idea of studs (yes its a 2 bolt) and ARP's did cross my mind at one point and after selling some parts this weekend I just might do it. How much of a differance will this make in strength? thanks 76zimmer, J
  5. 76zimmer
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    It won't be a 4 bolt, but somewhat in between a 2 and a 4.
    Arp's are great insurance.
  6. 76zimmer
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    Give 4x4high a PM, he can answer with more experience than I.
  7. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    Those heads are peanut port, so high RPM's are out. The carb and intake are probably to large and more info would be neccesary on the cam.
    Of course, I'm no engine builder, but my 2/100.
  8. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    any big block cam swap over stock requires new valve springs. some on here have found this out the hard way.
    and if i could i would spurge on a set of full roller rockers. nice 15-20 hp and much more acurate ratios over stamped stockers. plus bbc come with studs in them with guide plates so its a basick bolt on. and the motor will love you for it.
    if at all possible ditch the peanut port heads. i got a set of 3917219 heads remaned from a old build years ago that got better heads installed. thay have been sittin here for a few years. shipping to you might be in a good ball park with my price. pm me if you want to talk.
  9. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
  10. sweetk30
    Nov 1, 2004
    25,548
    543
    bad side of wrong springs is coil bind /valve springs break /droped valves. as allen mountainexplorer. he has seen it and fixed it and posted pics before.
  11. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    The cam and intake both have a listed power range of idle to around 5500rpms so I thought they would be ok with my heads. I really want a truck avenger carb on this motor and I thought the 670 would be to small. Anyone else care to comment? Thanks for the .02 77fixer.
    PS I hope the cam and intake work as I already bought them.:(
  12. 76zimmer
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    You got some good experience talking to ya here, don't just throw a engine together and hope it works out alright, that gets expensive (done it)
  13. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    I agree, thats why I posted up here! :bow: I am on a budget but I cant afford not to make it reliable as I hope to get a couple years out of this motor. I priced valve springs ,ARP rod bolt and main studs, I can swing those but the roller rockers are out for now.
    Does anyone else think this cam/intake/carb choice is to much? Thanks for helping out a newby to engine building, J
  14. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    I hate to say it but those heads are really going to choke your HP. Ask me how I know. If you don't mind having 200hp max at the rear wheels then go for it. After my last dyno with peanut port heads, I will NEVER run a set again. I think the low mileage set I had after my last BBC build, I just gave away.
    If it was me on a budget, I'd stay with the stock rotating assembly with decent pistons and do better heads like the 049's or 781's. The non OEM alum heads are even better for flow.
    Oh and that manifold won't work well with those peanut heads since you're going from a larger runner in the intake to a smaller runner in the head. This causes your flow to decrease even more.
    A good book to read on BBC's is this one here:
    http://www.amazon.com/Big-blk-Chevy-Hp1216-Dave-Emanuel/dp/1557882169/ref=pd_bbs_7/103-9323774-7877467?ie=UTF8&s=books&qid=1175055342&sr=8-7
  15. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    The stock crank, two rods and one piston where all junk when I tore this motor down and the price of the Eagle kit wasn't much more than buying new stock stuff.
    sweetk30 pm sent
  16. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    I called RPD racing and they said the rods come with ARP bolts so I will not have to buy those. They are not wave locks though.
    Wow, 200 rear wheel horse! That sucks, I was hoping these heads would do a little better than that. Well I guess I will have to live with it untill I can afford better ones. Even 200 rwhp is more than my old oil burning turd eating 350 is making now!:( Thanks again for all the info guys, J
  17. Shawn
    1,753
    5
    5280'
    Yeah, you can read about more here and theres a few pics of it on the dyno. Torque is okay but HP sucks with the peanuts.
    http://www.off-road.com/chevy/reviews/comp/
    Later I decided to build a 496.
    http://rubicon.off-road.com/chevy/tech/454engine/
    It didn't last too long since the cheap machine shop ****ed up the shortblock build and spun main bearings after 3k. You get what you pay for sometimes. :(
  18. sweetk30
    Nov 1, 2004
    25,548
    543
    yes yes yes find and reserch a good machine shop.
    we have 2 local socalled motor build hp shops in town. i wouldnt send a lawn mower block to them.
    but we have a guy 30 min up the road who only does machine work only. no diss / reassembly work. he is hands down the man in this area. he has 1-3 month waiting list and some times a bit longer. and ha has fair prices.
  19. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
  20. Hoot
    Hoot Registered Member
    Mar 25, 2007
    54
    Las Vegas, Nevada
    Doug Thurley Headers, would be my choice.
