454 Burb trouble code?
Discussion in 'The Garage' started by pismorat, Mar 27, 2005.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    My dad's 4wd 1999 Burb, when towing our Weekend Warrior, keeps throwing an "engine misfire" trouble code. It happens consistently when the engine hits 4250 rpms (in first gear climbing a steep grade). I'm wondering why this is or what will fix the problem. Also, any tips on squeezing more power out of this 454? Thanks.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    So what is the code number? "engine misfire" is pretty vague.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Is this the type that uses a central TBI unit with port injectors between an upper and lower intake manifold? If so the lines to the injectors on the SBC's like this have been known to leak and cause that exact problem.
  4. pismorat
    Oct 29, 2002
    540
    California
    It's code PO300, it does is consitently at 4250 rpm, it has fuel injection, not TBI. When I run the OBD II it just says Engine Misfire Detected. I'm changing out the plugs this week, but they looked ok to begin with. What do most 454's redline at?
