454 casting numbers, help!
Discussion in 'The Garage' started by 32ford, Nov 18, 2006.
  1. 32ford
    32ford Newbie
    Nov 18, 2006
    4
    El Paso, Texas
    Hi there! I have a 1932 Ford Model A with a sbc 265. I just got a 454 from a friend of a friend... I was told it came out of a mid 80s truck. I need help in reading the cast numbers on the block. the numbers to the right of the dist. are 14015445 and to the left are 324. both side of the block right below the heads has the liter stamped of 7.4. Also, when I look for parts i'm asked what generation is it? I think it is a Mark IV. Please help!
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I can't really help you with the casting #'s but you may want to change your post title to something like "454 casting numbers" to generate a better response
  3. 32ford
    32ford Newbie
    Nov 18, 2006
    4
    El Paso, Texas
    Thanks I think I will change thanks.
  4. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    14015445 is indeed a Mark IV block. I have a 5445 block that is 4 bolt main but I've read that casting can be either 2 or 4 bolt.
    Post up the casting # from the heads and we can tell you more about them also. If it's just a cruiser pretty much any head will be fine but if it's going to be a thumper then some heads don't flow well enough (the ones with my 5445 were not the good ones).
  5. 32ford
    32ford Newbie
    Nov 18, 2006
    4
    El Paso, Texas
    The numbers off the heads are 14081045 and the ports are rounded.
  6. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
  7. 32ford
    32ford Newbie
    Nov 18, 2006
    4
    El Paso, Texas
    Wow you guys are great! So how about those heads, are they good?
    P.S. Sempier Fi k30bb468!
  8. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    (From Mortec)
    14081045...78-87...oval...OPEN...454
    I'm not familiar with this casting but I'd bet they are the late model "peanut" port heads that are less desirable for performance applications.
  9. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
