454 exhaust
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by hawaiik5, Sep 24, 2001.
  1. hawaiik5
    hawaiik5 Newbie
    Jun 30, 2001
    4
    Hawaii
    hello everyone,
    i am getting a parts truck that has a mildly built 454 that i wanted to swap into my k5. i was wonderingwhat size pipes i should use, has headers and some bolt-ons and the heads have just been rebuilt about 5000 miles ago. anything i should look out for with this swap. advice, ideas?
    dennis
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'd say 2.5" for duals, or 3" for single. As for the swap, make sure to use brand new motor mounts, and drop it on in[​IMG]
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    If the motor is a High reving motor i would go with Dual 2 1/2's.
    The Single 3" is going to give you better low end, I think they sound better to. On my old blazer it had a built 400 in it. I had dual flowmasters, when i went to the single 3", it improved my mileage 1 or 2 mpg, Big difference in low end. I would also go with the Doug Thorley Tri-y headers if it isnt a high reving engine. Even on my 6.2 diesel the single 3" works better. It opened it up quit a bit compared to the duals.
    4 wheeling is like sex, when its good, its really, really good, when its bad its still pretty good.
  4. hawaiik5
    hawaiik5 Newbie
    Jun 30, 2001
    4
    Hawaii
    should i use motor mounts for a 350? the 454 is currently in a 74 3/4 ton 2wd truck with an automatic and my k5 is an 82 with a 350/sm465. will the radiator and brackets bolt up to my k5? what about flywheel/clutch, i was thinking of getting one for a 74 3/4 ton 4wd with a sm465 and a 454. is there anything else i missed? any ideas, advice?
    thanks
    dennis
  5. hawaiik5
    hawaiik5 Newbie
    Jun 30, 2001
    4
    Hawaii
    i think i'll go with dual 2 1/2" with flowmaster 40 series since this truck will see a lot of mud when i'm done. btw the truck already has headers that i think i will reuse.
    dennis
