454 flywheel question
Discussion in 'The Garage' started by big83chevy4x4, Oct 14, 2006.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    last week i bought a 99-00ish vortec 454 (gm test motor, has some not so 454 items on it, more like 496 stuff on it.) ive been looking for a flywheel but i can't figure out what fits. some web sites say all 454 flywheels are the same, some say up to 90, then 91 on are the same, some say up to 90, 91-95, and 96 on.
    GM sells a flywheel for this for around $100, but it says 11" pressure plate pattern. i want to put a 12" clutch on it. if my local dealer had one in stock, id just take a measurement to see if a 12" clutch will fit. but they don't and if i order it, im stuck with it.
    anyone know if it will fit or know of what flywheel that will fit the new 454 and a 12" clutch?
  2. dyeager535
    26,982
    191
    I hope someone will post up about the clutch size. I had always heard there were only two sizes, 11 and 12", but then found out that one is something like 10.4" or so.
    It MIGHT be that the GM piece is 11.4 or something, and that's what everyone calls a 12"?
    Ring gear count will tell you if it's a big or little flywheel, 168 tooth is big, 15x is small. Unsure if the tooth count changed later on.
  3. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
  4. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    This is what I found. I thought the only differance was whether it was a 1 piece or two piece rear main, but maybe not. I see three differant types and they seam to be interchangible only in between the specific year models.
    http://www.coloradok5.com/forums/archive/index.php/t-123526.html
    http://store.summitracing.com/partdetail.asp?part=HAY%2D20%2D330&view=32&N=700+115&orig=1
    http://store.summitracing.com/partdetail.asp?part=RAM%2D2532&view=32&N=700+115&orig=1
    http://store.summitracing.com/partdetail.asp?part=MCL%2D460130%2D4A&view=32&N=700+115&orig=1
