454 fuel injectors
Discussion in 'The Garage' started by CyberSniper, Jan 19, 2004.
  1. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I'm after 454 fuel injectors. Either the 80 lb/hr or the 90 lb/hr ones. I might even take Pro-Jection injectors since they fit the hole too.
    GM Parts Direct sells brand spanking new #17113080 injectors for $100/each. Anybody know where else to find some for less? I'd even take reman injectors.
  2. fly_n_hi_yukon
    fly_n_hi_yukon Registered Member
    Jul 8, 2003
    44
    Strange Range, MI
    Too bad you're not after MPI injectors. I've got 8 brand spankin' new injectors from a MerCruiser 454 MPI... /forums/images/graemlins/thumb.gif
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    If I could find a complete MPFI intake with throttle body that works with a regular distributor fo' cheap... then yeah. haha.
    EDIT: That reminds me, did you premanently borrow those from... hehe.
  4. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    The 454 injectors flow much more than any other injector, including the pro-jection units (I'm referring to the 670 CFM unit). $100 a piece sounds about right, you're going to have a hard time finding them elsewhere, you might want to check Turbo City as well. Keep in mind that the 454 injectors will not work with a stock small block PROM (if that's what they will be used for). What are you wanting to do with them?
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Well, going by the pictures, some of the Pro-Jection throttle bodies use the same injectors that fit GM's TBI-220 throttle body. They also seem to use Mopar injectors.
    Chevy on the left, Dodge on the right
    Why won't the injectors work with a smallblock PROM? Aren't they both the same type of injector?
    They're going to get stuck in a smallblock throttle body and used in a custom application.
  6. fly_n_hi_yukon
    Jul 8, 2003
    44
    Strange Range, MI
    Perks of the job...
