454 fuelinjected probs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K10ANDYKHAMNIC, Nov 27, 2001.
  1. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    hey all my dad had an 87 1 ton crew cab 4x4 ack i want it haha , anyways the enigne he said sometimes kinda intake backfiresor sumthing like that , he suspects sticky valves ,the p o said it had had valvework before ... i suggested cleaning the throttle body and checking the maf .. anything else ?
    dents ....
    O R D's axles
    NO BREAKAGE :)
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Hey Andy, sounds like it either jumped time at the chain or its firing at the wrong time at the distributor.
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://www.echobit.com:81/k5/> Pictures</a>
  3. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    he said it only does it veryseldomly tho
    dents ....
    O R D's axles
    NO BREAKAGE :)
  4. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Then its more likely a distributor timing issue. The timing may be shifting due to either vacuum problems or in some computer controlled ignitions a bad sensor ( air flow meter, etc.)
  5. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Is it popping through the intake or exhaust? May need to check the "air injection" system that supplys air into the exhaust manifold (and on some, the cat also). If the valve is hanging up/inoperative oxygene cooks off (backfires) in the exhaust. A good shop manual can explain this far better than I can.
    Real trucks don't have spark plugs!
