454 head pipes, 350 engine
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, May 5, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok i have a complete pair of custom bent or possibly OEM exhaust pipes from a 74 C20 454 pickup i cut up last fall and i have an 82 c-10 longfleet 2wd that is SBC truck, now is there any chance of the 454 head pipes working with for a 350 with 70's style stock manifolds ? the 454 had stock manifolds on it too. (older regular 3-stud flange type manifolds setup)
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    No, the big block's all have a single port for each exhaust valve, whereas a small block has the two center [siamesed] port's. And the big block head's are longer than a small block.
  3. KShortell
    KShortell Registered Member
    Jun 11, 2001
    44
    Bel Air, Maryland
    I don't have an answer. But, to clarify this-- he's talking about the doughnut gasket joint for the head pipe connection to the manifold.
    Kevin
    /forums/images/graemlins/burb.gif
