454/Headers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by crookedunit, Dec 20, 2003.
  1. crookedunit
    crookedunit Registered Member
    Dec 7, 2003
    6
    If a put a 454 in my 73K5, will there be room for headers? The headers on my 350 fit pretty snug.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, there are a few out there. Doug Thorley Tri-Y's fit just fine. /forums/images/graemlins/thumb.gif
  3. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    The big block heads are going to sit farther over the top of the frame, (provided you use the motor mounts from the 350). The big block headers will fit snugly, and will probably rub the frame, but a little finessing with a hammer and dolly you can flatten a spot on the outboard side of the header so it will clear the frame and not rub.it doesn't have to be much more than a 1/2 inch. If you go with a solid motor mount even less.
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I have Doug Thorley Tri-Y's on my 454 in my K5...The fit perfectly...The only issue with the installation is that I had to remove one of the factory bumpstops ont he pass. side and since mine is a TBI motor, I had to modiffy the knock sensor connector a bit to clear the headers...
    Chris
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I put thorleys on my 496 and i hadta jack the motor up to get em in.
