454 in my 77 k-5
Discussion in 'The Garage' started by Danny Joe, Jul 20, 2005.
  1. Danny Joe
    Danny Joe 1/2 ton status
    Feb 10, 2005
    134
    Blythe,California
    Does anyone know how much trouble would it be to put a 454 into my 77 k-5 blazer. would it bolt right up to my automatic turbo 350 tranny. are the motor mounts the same. I just dont know. Any info would really help. Thanks, Danny Joe. My email is ltdanjg69@aol.com
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    It is a piece of cake....Keep on the lookout for a beefier trans and possibly a bigger radiater though....
    The exhaust will probably need some reworking to hook up.
    Nothing to major, drop it in and grin....
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    It should work. I think you will use the BBC motor mounts.
    I have a 454 for sale. PM me if your interested. :thumb:
  4. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    I just did one not too long ago and ya gotta move the frame mounts, no bigee the holes are already there. :bow:
    pulled a 305 and stuck a 396 in the hole....
  5. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Everything is a bolt in swap. You will want to consider running a 4 core radiator. If you do, do yourself a favor and use either the factory one with a new top plate, or spend the $$ on a thick aluminum one. The cheap aftermarket ones that drop into the stock location of the 3 core really don't work very well.
    Since you are running a 350, the motor mounts are the same as well as the location of them. You won't have to move anything.
    Also, keep an eye on your tranny. There are a lot of rigs that run the 454/TH350 combo, but most of the TH350's have been modified to handle the torque of a 454.
    If your rig still has the 1/2 ton axles in it, go easy on the skinny pedal. Oterwise, you'll get to see the insides of your axles and you won't even have to pull the diff covers off. :D
  6. greg mgm
    greg mgm 1/2 ton status
    Apr 6, 2005
    152
    Pine Cove (near Idyllwild) CA
    I swapped the 350 from my 78 truck, and went with a 454. Whatever trouble you deal with, just do the swap!! You will love the big block power. Also, I needed a set of brackets for the accessories, maybe they'll come with your engine?? For sure, upgrade the radiator.
  7. Danny Joe
    Feb 10, 2005
    134
    Blythe,California
    Big for sale
    Just wondering whats been done to it and how much? Thanks, Danny Joe.
  8. MEGALADON
    MEGALADON 1/2 ton status
    Feb 4, 2005
    214
    HOUSTON
    Very easy swap, don't have to move motor mounts :bow: bolts right in..
  9. Danny Joe
    Feb 10, 2005
    134
    Blythe,California
    Thanks, Any future plans for your rig.
  10. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    I got new wheels, my 454 is in, and I'm in the middle of a overdrive swap :D
    Good luck with your swap :waytogo:
  11. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    What type headers? Do they fit good? By that I mean will the hit stuff under offroad conditions.
    I know It's not been offroad yet but IYO?
    O' sorry for the hi-jack, I just did the same swap and can't find a header thats worth a s@#%!
    Thanks Jeff
  12. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    I have cheap $125.00 hooker headers, and they really suck, they hit the leaf springs
    and they hit the driveshaft :mad: If you look at the last pic, you can see how the driveshaft has a ring from rubbing the header.
  13. JeffHK5
    Mar 16, 2005
    544
    Cincinnati
    They should let you put those pics. on the side of the header box so people don't waste there time!
    And it's not just Hooker, Hedmen and Flow-Tech fit just as bad! :mad:
    I think I'm going to try blockhugger headers from Summit as they are cheap and if they don't work I'm only out 129.99.
    Might go for some stacks out the hood , like a pulling truck :haha:
    If you find a set that works PLEAESE let me know.
    Thanks Jeff
