454 leaking oil. Have some questions.
Discussion in 'The Garage' started by Esteban86K5, Sep 28, 2004.
  1. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    The 454 in my 2wd 87 Burb has leaked oil all over my driveway since i bought it a few months ago. I haven't pinpionted the exact location but I am going to be pulling the tranny out to replace the flywheel so i thought I'd replace the rear main seal while I was there. I have done it on a 350 but never a 454. Is it basically the same? Are they a one piece design or 2 piece. And I am assuming the oil pan can be dropped without lifting the engine right? I also have to replace the exhaust manifolds since the ones in there are cracked. Can anyone suggest a good gasket for those? Some work better than others? I have used Fel-Pro before and got good results. Anyone use something else they like?
    I want to gather all the info and parts I need before I tear into it to eliminate down time on it.
    Sorry for all the NOOB questions. The 454 is just a new creature for me. I'm used to the puny 350. /forums/images/graemlins/doah.gif
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Well, I'm not much help for you but I can say I like Victor Reinz gaskets better than Fel Pro. My 406 is starting to leak in a couple spots and I used a fel pro kit. Our older 454 in our '76 C30 leaks oil like a sive /forums/images/graemlins/doah.gif But our Vortec 454 in our 98 C30 doesn't leak a drop. /forums/images/graemlins/dunno.gif
    Someone will correct me if I'm wrong but I think your 454 should be a 1 piece rear main if it fallowed the trend of the 350. That is a big if on my part though, and someone will hopefully correct me if I'm wrong.
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    An 87 454 is a Mark IV plant. Two peice rear main.
    You do not have to jack the engine up to remove the pan(bless GM's heart)
    Easy job to do.
  4. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    If I were you try and get OEM gaskets, they should still be available. PM me if you want me to look em up for you at work.
  5. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    add 60 cubes... that otta fix it /forums/images/graemlins/histerical.gif
  6. Esteban86K5
    3,712
    Bakersfield, CA
    What is this Mark IV plant you speak of? /forums/images/graemlins/dunno.gif
  7. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    I dont use exhaust manifold gaskets anymore--they always burn away and leak.Most engines from chevy had none factory,the manifold and head are planed flat and installed without any gasket.You may need them if the manifolds are warped,but they wont live long--your better off having the manifolds trued up on a surface planer and using no gaskets.
    This does not apply to headers--only stock cast iron manifolds. /forums/images/graemlins/crazy.gif
  8. Esteban86K5
    3,712
    Bakersfield, CA
    That's good info. I'll have to call around to see how much that'll cost. Thanks /forums/images/graemlins/thumb.gif
  9. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I had good luck with mainfold gaskets before I went the header route. Oh and I think Mark 1V is just the generation of the motor.
  10. Grim-Reaper
    7,385
    Atlanta
    My 88 454 is leaking from the back of the intake manifold.
    Dropping a pan is a LOT of work at a guess. I would be damn sure that is what it was befor commiting a day to changing it. Get a light and you can look up the back of the engine and verify if it is leaking at the Valve covers or intake.
    Dropping the inspection cover you should be able to look up between the fly wheel and block enough to tell if thats the source of the leak.
  11. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    The MK 4 is the original style of bbc with a 2 peice seal. The gen5 came out in 90-91 and went to the one piece seal, gen 6 in 96 added the provisions for roller cam, the one peice pan gasket, and 6 bolt timing cover.
  12. Esteban86K5
    3,712
    Bakersfield, CA
    Considering I dont have an inspection cover it should be even easier!! /forums/images/graemlins/waytogo.gif
    I was planning on taking it to the local coin op wash ans clean the engine really good before I did this. Hopefully this will also help pinpoint the problem area! /forums/images/graemlins/dunno.gif
  13. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Steam the motor off and get some dye additive for the oil. Then use a "black light" to trace the leaks. /forums/images/graemlins/thumb.gif
  14. Esteban86K5
    3,712
    Bakersfield, CA
    I've heard about that dye. Does it actually work /forums/images/graemlins/dunno.gif?
  15. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Yes it does. But you may find more leaks than you want to fix..
    /forums/images/graemlins/whistling.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    John
  16. Esteban86K5
    3,712
    Bakersfield, CA
    Where do I get the dye for this? I have sen it for the AC system but never for the motor oil. /forums/images/graemlins/dunno.gif
  17. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    TracerLine
    Here's a company. They are pretty popular. Click on the "where to buy" link.
    It looks like they had a couple dealers in the Bakersfield area.
    John
