454 mystery knock
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by agrezy1, Jan 5, 2003.
  1. agrezy1
    agrezy1 Registered Member
    Dec 14, 2002
    49
    yucca valley,ca
    got a mystery knock in 454 its not in my burb but in my motorhome the knock does not sound like a rod its like a light knock all the time can here it mostly from top of engine and pass. side outside sounds like a rotating knock heres what i have done so far,,ran motor with all belts off,new water pump pulled fuel pump out along with rod pulled intake and inspected lifter valley,checked end play on crank changed flexplate and trans all this made no differance the knock is not loud enough to here over 1500 rpm the guy i bought it from says the whole time he owned it never got worse and he put 25,000 miles on it am i just being paranoid? its a 1985 carb.model with factory oil cooler any help woud be great.
  2. unsane
    unsane Guest
    Timing? Anyone else?
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Could be cam bearings maybe.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    How about a lifter? /forums/images/graemlins/confused.gif
  5. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Yeah, a stickey might do that.
  6. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Are all your plug wires in good shape? When my parents got their motorhome it had a tapping sound, kinda like a loose rocker arm. Turns out there were a couple wires loose that were jumping fire.
  7. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    try cleaning the top of the pistons with some injector cleaner it could have some carbon built up on them . i had a 86 454 that had a knock and thats what it was .
  8. motorheadnelson
    motorheadnelson Registered Member
    Aug 12, 2001
    80
    Fort Mohave AZ
    Possible wrist pin/ cracked skirt, but they usually are loudest when cold. Maybe even something as simple as an exhaust leak.
  9. Ditchdigger
    Ditchdigger Registered Member
    Mar 11, 2001
    96
    The Great Midwest
    Try lookin at your Exhaust Manifold gasket,
    I have been fooled before where I thought it was
    a lifter and turns out to be an exhaust leak
  10. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    Motor Homes are nortorious for exhaust manifold leaks. I would look there first. They generate so much heat, I've seen the manifolds warp so bad that the shear the bolts off the head and warp like a banana! Hope this helps!
