454 Oil Cooler Adapter removal - How??
Discussion in 'The Garage' started by vette_dude, Feb 19, 2007.
  1. vette_dude
    vette_dude Newbie
    Feb 19, 2007
    4
    Austin, Texas
    I am working on a friend's '90 3500 4x4. It is leaking at the oil cooler adapter. How do I remove the adapter? My stepson got under there on Sat and removed one of the pipe plugs on the bottom of the adapter, but saw no bolts. This is leaking pretty bad, so we need to get it removed and new gaskets installed. The Chevy Service manual was useless. Can anyone help??
  2. waywest
    waywest Registered Member
    Feb 5, 2007
    11
    Marana az
    my 78 454 had two allan head bolts holding it on.
  3. vette_dude
    vette_dude Newbie
    Feb 19, 2007
    4
    Austin, Texas
    Where were they? under the pipe plugs???
  4. waywest
    Feb 5, 2007
    11
    Marana az
    inside under the filter.straight across from each other
  5. vette_dude
    vette_dude Newbie
    Feb 19, 2007
    4
    Austin, Texas
    On this one ('90 454), the filter is moved to the side so it goes in at a 90 degree angle (horizontal) from normal.
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    It is held on with bolts under the pipe plugs. I recently rebuilt a 1990 454 with that exact cooler adapter.
    IIRC the bolts were torx head.
  7. vette_dude
    vette_dude Newbie
    Feb 19, 2007
    4
    Austin, Texas
    Scott -
    thanks for the info. you remember very correctly. it was indeed torx (T40). But the front bolt requires a long (3""+) extension to get to it!! So I dont quite have it off yet... this weekend.. again thanks for the info..
    michael
