454 owners:Does tranny dipstick fit?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer79, Feb 9, 2002.
  1. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Hello guys & girls:
    I had my 454 swap project halted for a while, but finally I'm going to have some time tomorrow.
    How did you route the tranny dipstick tube? Mine doesn't fit between the valve cover and the firewall? I tried bending mine, but it seems it will get pinched. Or did you just whack the firewall?
    Any input welcome.
    Thanks.
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I had troubles getting the tube from my TH350 to fit... but I eventually bent it up well enough to get it in there! [​IMG] Then the TH350 smoked, so in wen the TH400 from a donor 79. That trans and tube dropped right in without a problem. If all else fails, maybe you could just get the tube at a local yard?
    Good luck! [​IMG] Make sure that the angle of the tube is as close to stock as it enters the trans... if its at a severe angle, the little rubber seal will leak like no tomorrow! [​IMG]
    <font color=red>GOT MUD???</font color=red>
    <a target="_blank" href=http://home.attbi.com/~netwrite>Midwest Caravan</a>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s - 36" TSLs
  3. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    If you can't make the stock tube fit, there is another alternative from Lokar. They make <a target="_blank" href=http://www.lokar.com/Products/FlexibleTransmissionDipsticksPage.htm>flexible transmission dipstick assemblies</a> that are pretty slick, and will work in just about any situation.
    Robb
    <a target="_blank" href=http://community.webshots.com/user/robbrj>'73 GMC Suburban - 502DFI</a>
