454 Radiator in 88 K5? Will it bolt up?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Oct 1, 2001.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I need a new radiator in my truck.I have been told to put in one from a 454 burban, will it bolt up or not? Any problems I can run into? What year burban should i specify? Will it over cool it? I am running a brand new 350HO, w/ 36" swampers. Radiator isn't that hard to replace is it? Any thing else I need to know? Thanks!
    Dawson
    Raleigh, NC
    88 K5, 6" lift, 36" TSL Radials, 14 Bolt, Rancho 9012s
  2. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I put a 4 core into my '84 Blazer when mine needed to be replaced. No problem finding one for my car. Really easy to install too.
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  3. I have an 88 Burb with 350 and a 700R4. I used one from AUtoZone Part# 433730 ($170)and then went to the GM dealer for the 4 pads Part# 6264100 and one panel part #14018600, and the shroud is part# 14021289.
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>I Like my Burb'n on the ROCKS !!
    <font color=black>Imported to Kentucky through military channels !!
  4. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    recently put a 4 row in my 91 sub (350/700R4) from Radiator.com . It ran $133/delivered!
    Had to mod the shroud a bit and went to local dealer for the new mounting rubbers (about $4/5 each). It seems to run a LOT cooler now (closer to the 160 thermostat setting for a change!)
  5. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Why do I have to get a new shroud? Whats wrong w/ the stock one? Thanks!
    Dawson
    Raleigh, NC
  6. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Is all you had to do is get the mounting rubbers, or did you have to get a new support piece like big burb mentioned?
    Dawson
    Raleigh, NC
  7. woody9
    May 27, 2001
    602
    Howell, MI
    I got the 4 row mounts from the dealer, and 'adjusted' my top support a tad. Also used my shroud with a bit of mod to the it as well. Just bracketry and such.
  8. The bracketry is different from the stock type. I used only the top half of my old one and cut it down to fit. It isn't the prettiest, but it works fine.
