454 radiator in a 1/2 ton question
Discussion in 'The Garage' started by bigburban383, Mar 5, 2004.
  1. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Do you need any parts/adapters to make this work? Tranny cooler lines the same size? Larger coolant hoses?
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    You need a new top plate for sure, and I remember hearing somewhere that you need adapters to fit your tranny lines. Not sure of anything else. /forums/images/graemlins/dunno.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nope tranny lines are the same.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you will need four core mounting brackets, if is 81up, and new top plate for four core if is 73-80
    if is 82-up then i have four core pair of brackets you will need
    also sometimes the top rad hose port on four core is smaller diameter than 2 and 3 core, it was this way or my 83 2 core rad to 74 style 4 core swap
    the 2 core hose was too large diameter for the 4 core rsdiator
  5. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    And if you plan on running a fan shroud then you will need to either modify your existing one or buy the shroud from the dealership to fit the 4 core radiator, other than the bracket everything slides right in. I think this was one of the best mods i did. /forums/images/graemlins/peace.gif /forums/images/graemlins/k5.gif
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i might still have a 73-80 style 454 shroud around here is someone was needing, unless i scrapped it, hmm.
  7. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I needed the 2 top metal brackets and 4 of the little rubber cushions on my 87 when I put the BBC in there with a 4-core...
    Chris
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i dont know if i can be of any help regarding all four cushions,.
    no one carriers fore core ones ?
  9. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    tranny lines and hoses are the same. The fan shrouds are different. The stock BB upper supports are 1 piece, but you can use your stock 2 piece bracets and move them out. the core supports are usually set up for either mounts.
  10. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Hey R72K5 if you dig up that shroud woulda mind partin with it? PM me if so.
  11. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I got all my stuff from the GM..itwas like 12 for the metal brackets and like $3 a piece for the cushions...
    Chris
