454 rocker arm torque settings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBadCad, Nov 12, 2002.
  1. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    I will be replacing a broken rocker arm this evening and was wondering if anyone could provide me with the initital torque settings. I also assume that I'll have to drop the oil pan to remove any metal chips/chunks from the broken rocker...any other tips?
    thanks in advance
  2. ratlover
    ratlover 1/2 ton status
    Aug 5, 2002
    215
    Peorial IL
    The stud or the actual rocker arm? How you adjust the rocker arm is dependednt on what type of cam you have. Is it solid or hydralic?
  3. BigBadCad
    Dec 18, 2001
    109
    minneapolis, mn
    The stud is fine, I just need to replace the rocker arm and pushrod.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There isn't a 'torque setting' for rocker arms. You have to get the cam lobe for that cylinder on the base circle, then crank down on the rocker arm nut while spinning the pushrod between your fingers. When you feel drag on the push rod, then you've taken the slack out of the valvetrain for that particular valve. Tighten the rocker arm nut another 1/2-turn and you should be good to go. /forums/images/graemlins/thumb.gif
