454 Swap
Discussion in 'The Garage' started by txfireman110, Mar 25, 2004.
  1. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    Can't find anything in search /forums/images/graemlins/dunno.gif
    Where can I find detailed info on swapping a 454 into my K5 w/ a 350?
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    What's to know? Should be a direct bolt in. You just need all the big block pulleys and exhaust. Will bolt right to the tranny too
  3. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    The TH400 attached to the 454 is going in with it! Let me ask more specifically, will the tranny crossmember be the same, and it seems I heard something about the crossmember in the front. Sorry for the newb ?s, never done a swap before, so just being cautios!
    (Thanks bigpapa)
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the front cross member difference is the motor mount bolt pattern. you can't put sbc mounts in a bbc original truck and vice versa. the sbc mounts will fit a bbc and sbc, i don't think the crossmember moves unless you are changing trannys, then its iffy
  5. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I swapped a 454/4 speed in place of a straight 6/3 speed manual. Direct bolt in. Got lucky and didn't even have to change driveshaft length
  6. justinf
    justinf 1/2 ton status
    Sep 23, 2003
    684
    Tuscola, Illinois
    I put a 454in an 84 stepside, it bolted right in, no problems. What are you using for a transfer case?
  7. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    NP205 /forums/images/graemlins/peace.gif
