454 swap.
Discussion in 'The Garage' started by shaun, Mar 30, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    I want to put a tbi 454 or 396 in my 90 jimmy. I have some questions though.
    1. Will any of my stock computer and wiring work or will I need the 454 tbi wiring also.
    2 If I use the edelbrock mpfi setup can i order the one for a 454 and will it have all the new stuff i need to use my remaining stock wiring on a 454.
    3. Will the 454 tbi or mpfi work on a 396?
    4. Will I need any frame mods or will the BB motor mounts bolt up to my stock 1/2 ton frame.
    I hope these make sense. If not I can elaborate. With my truck my mind goes faster then my hands /forums/images/graemlins/waytogo.gif
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I cannot answer your TBI questions.
    Your stock crossmember will work fine with a BBC.
    I belive the 396 & 454 are the same externally.
    Good luck
    I can't wait to drive my BBC /forums/images/graemlins/peace.gif
  3. shaun
    Apr 22, 2003
    745
    What about the mounts. And thanks for the info.
  4. Burt4x4
    6,854
    GM uses the same bolt pattern on the blocks for the engine mounts.
    There are some x-member & engine mounts that are different but thoes are the original rigs that came with a BBC from factory.
    ORD sells engine mounts that bolt right up to both SBC and BBCs. So originally equipt SBC trucks/Blazers will accept a BBC just fine. If you have a manual tranny you will need a new flywheel(454) and cluth. If you are Auto then the recomendation is to swap in a TH400 or that other big block tranny that I don't know the name of /forums/images/graemlins/pimp1.gif
  5. shaun
    Apr 22, 2003
    745
    I would like to run a 700. I am thinking about a bowtie overdrive 700 or a raptor 700. They are supposed to hold atleast 500 horse and torque. And since I will never be that high you think that would be alright. Thanks for all the help. /forums/images/graemlins/peace.gif
  6. Burt4x4
    6,854
    I don't know didly squwat about auto slushboxes /forums/images/graemlins/whistling.gif except they over heat and catch fire eaisly /forums/images/graemlins/ignore.gif /forums/images/graemlins/whistling.gif
    hehehe
  7. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    They should all bolt up but the 454 is externally balanced so you need flywheel for the big block the 396 I believe is internally. /forums/images/graemlins/waytogo.gif
  8. shaun
    Apr 22, 2003
    745
    More info yes give it all to me. Anything on the wiring and stock sensors???????? /forums/images/graemlins/confused.gif
  9. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Depending on the year of the 454, yes all you juck from you 90 will work prefect..I swapped in a 1992 TBI 454 into a 1987 K5. I kept my stock 350TBI wiring harness but I had to change about 70% of the connectors. The newer 454 had differenct connectors than the one on my older 350.
    Chris
