454 swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dumbfounded, Aug 9, 2000.
  1. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    Since I saw a couple of posts on 454's. Was wondering what was involved in a swap on a 78. Headers, THE MOTOR (of course), what else? Motor mounts? Any headaches you all have encountered?
    Love, Peace, and Hair Grease...........
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    headers and all pulley's make it easy. the mounts are the same. pulleys and p/s brackets are different.
    your right. I don't understand the jeep thing!
  3. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    A larger radiator is needed. Usually a 750+cfm carb is also needed.
    Shawn
    87 K5
    few mods
  4. LittlePig
    LittlePig 1/2 ton status
    Aug 9, 2000
    299
    East Texas
    Remember the 454 is externally balanced, so make sure you get the flexplate/flywheel that goes with the engine, since your 350's flexplate/flywheel is for an internally balanced engine. You will need different motor mounts. Also, you should get a bigger radiator, since the bigblock puts out a bunch of heat. Just a quick aside, before you put in the big block, look into getting a kit (don't remember who it was made by) that brings extra oil up to the cam, as big block Chevys are known for under-oiling and thus ruining cams.
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    BC Engineering makes the overhead oiler kit.
    YEEEEE HAWWWWW[​IMG]
  6. Shawn
    1,753
    5
    5280'
    Have a # for BC engineering? Funny, I just posted this question on ORC and the mail list.
    Shawn
    87 K5
    few mods
  7. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    I couldn't find the number. I think it's in a 4Wheel & off-road magazine. I saw it in an article about 73-87 truck buildups.
  8. LittlePig
    Aug 9, 2000
    299
    East Texas
    I have that magazine,it has some good tips for doing block swaps. There is an article earlier in the magazine that talks about what you need to swap in a big block, along with stuff about transmissions and tcases too.
  9. Shawn
    1,753
    5
    5280'
    Thanks for trying. I'll look through my 5yr magazine stash and see if I can find it. Tried a search on a couple search engines and found nothing. BTW- It's not BC Engineering in AZ. I called them and they didn't know what I was talking about...
    Shawn
    87 K5
    few mods
  10. LittlePig
    Aug 9, 2000
    299
    East Texas
    Here is the number and address for BC Engineering:
    148 S 17th st.
    Grand Junction CO, 81501
    970-243-5438
    Email: xiaozhu@my-deja.com
    ICQ: 84108805
  11. Shawn
    1,753
    5
    5280'
    Thanks Little Pig!
    Just called and left a message with Bob.
    Shawn
    87 K5
    few mods
  12. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    Dont know if this applys to all blazers but I know on my 71 we had to hammer the firewall in a bit to clear the drivers side valve cover
    Your right I dont understand the jeep thing!?
  13. Shawn
    1,753
    5
    5280'
    My 87 had no clearance problems with the big block. Even with the tall valve covers, it cleared the booster and the large HEI doesn't hit the firewall. I would assume that would cover 73-91 bodies.
    Shawn
    87 K5
    few mods
