454 TB and plate
Discussion in 'Engine | Tranny | T-case' started by 1-tonmudder, Jul 12, 2006.
  1. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    This is a factory TB and adapter from a 89 K30.The plate has the spreadbore or Quadrajet pattern on one side so you can run a factory or aftermarket intake without buying a late style TB intake.TP sensor is missing.$200 and the ride.
  2. tuffdogstudio
    tuffdogstudio 1/2 ton status
    Nov 1, 2004
    239
    New Mexico
    what else is needed with this to ditch my carb and run TBI?
  3. 1-tonmudder
    Apr 24, 2005
    3,052
    A ECM and harness,electric fuelpump,and if you are going to put it on a 350 youll have to change to 350 injectors.Depending on whose harness you buy you can still run your HEI or change to a late model small cap dist.
    I am running this set up on a 350 with the small cap and a AFI harness and chip.
    You have to have the Quadrajet style intake it will not work on a Holley bore intake.
  4. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I have a complete wiring harness from an 88 V30 tbi 454. Includes computer. $200
