454 tbi oil pressure sending unit ?
Discussion in 'The Garage' started by K5DRAGER, Feb 4, 2003.
  1. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    I have a 454 tbi in my 88 crew cab and was wondering where the oil pressure sending unit was located. I know where mine is at but it sure doesn't look like it should be there. At least not mounted the way it is.
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    In my 1992 TBI 454, the oil pressure sender is in the very front of the block, on the drivers side, just above the oil pan rail...That is for a Gen V motor...Gen VI and Gen IV might be different...
    Chris
  3. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Yep, thats where mine is, but I still don't think its plumbed in right. Maybe I'm wrong, but it looks like a small piece of galvanized pipe coming straight out about 3 inches and then has a 90 degree elbow and then there's a bronze fitting that both the sending units screw into. Is this like yours? I wouldn't think the factory would use pipe would they?
  4. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    No, on mine the sender screws straight into the block...are you saying there are TWO senders off the one port out of the block? Yours may have been plumbed to run both the computer sending unit and the gauge sending unit off the same hole in the block...But my sender just screws in, perpendicular to the block, no piping or brass fittings...
    Chris
  5. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Yep both sending units are there. Where is your other sender at?
  6. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Um, I think that is the only one...My engine is at the machine shop now so I can't tell for sure...but I have the sender and it has a black plastic conector on it that has 3 prongs...maybe one is for the comp., one is for the gauge and one is a ground?!?!I dunno...If yours works and doesn't leak, I wouldn't be to concerned with it...
    Chris
  7. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Well thats exectlly the problem it does leak and it don't work, ar least right. I took it apart tonight and hopefully stopped most of the leak, except that the gauge sender itself is also leaking. So tomorrow I'm going to get a new one and hopefully fix the leak and the gauge. /forums/images/graemlins/wink.gif I was curious because I'm pretty anal about my daily driver and the PO has done some very stupid things at least electrically, so I'm kinda hesitant on what I find now. /forums/images/graemlins/smirk.gif Thanks for the info. /forums/images/graemlins/thumb.gif
  8. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Maybe just get the oil press. sender that has the 3 prongs and then get the appropriate connetor that fits and wire /forums/images/graemlins/thumb.gif
    Chris
  9. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    my 87 454 tbi crew cab, also has the pipe with brass t and 2 sending unit's in it.
    i just replaced the one that run's the gage also, the other one i just asumed ran something with the computer.
    dave
  10. Bigred86chevy
    Bigred86chevy Registered Member
    Jun 7, 2002
    38
    Stilwell, Kansas
    On my '87 K30 the fitting that the sending unit screwed into was cracked therefore causing a leak. When I went to remove it, it broke off in the block and luckily just enough was sticking out to get vice-grips on. It did look like someone just stuck it there and I couldnt belive GM would use such cheap fittings. As for the computer plug in. I just screwed my sending unit right into the block and did away with the plug in and I havent had any codes come up or any problems.
  11. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Thanks for the answer's guys, I can't beleive they would use that set up either. Oh well, off to get a new sender today.
  12. Dorothea
    Dorothea Newbie
    Jun 27, 2014
    Montana
    Sender 1992 Chevy 454 - Removal Tool?
    Is there a removal tool for the sender on a 1992 Chevy 454? I tried everything Napa and Car Quest has to offer, plus various wrenches, hammer and chisel. That beast is just stuck. Any ideas?
  13. dyeager535
    26,980
    What kind of sending unit do you have? 1 or 3 wire?
