454 tbi w/700r4?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tacoma, Jan 14, 2006.
  1. tacoma
    tacoma 1/2 ton status
    Jan 14, 2005
    317
    tooele UT
    I tried to search for the answer but apparently I can't put together a working combination of search terms, because I didnt' find what I was looking for.
    What would be needed to put a 700r4 behind a tbi 454?? is there a factory setup for the the TV cable that is out there somewhere???
    thanks for the help, in advance. :bow:
  2. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    the TBI on a 454 is not set up for a TV cable off of the 700R-4 it wont work and the factory never put a 700 behind a 454 thats why the TV cable issue is their
    LUKE
  3. tacoma
    Jan 14, 2005
    317
    tooele UT
    I figured as much... at 3:30am I was apparently thinking there were still 454 cars being made! duuuurrr
    I am going to assume for the moment that there is an aftermarket solution.
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    What i'm going to do is remove the side linkage piece off my 350 TBI unit and put it on the 454 TBI unit, problem solved. Yes, you will need to grind and weld but much easier than trying to fab up some kind of bolt on bracket or somethig and i'm sure it will take less time as well. :thumb:
  5. tacoma
    Jan 14, 2005
    317
    tooele UT
    That's not a bad idea. Probably pretty close... just dont' want to toast a 700r4.
  6. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The throttle shaft is in the exact same location as the 350 is so it will work perfectly.
  7. tacoma
    Jan 14, 2005
    317
    tooele UT
    then what do you need to grind/weld? I haven't compared the 2 yet.
  8. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The peice of linkage that your throttle cable attaches to is either welded or crimped onto the throttle shaft. Grind off the weld or crimp on both units then swap the 350 linkage plate onto the 454 TBI and weld it on. :thumb:
  9. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Sounds like a good fix for this problem.
    I guess I'll find out soon enough- I just scored a complete BBC TBI setup and a complete BBC serpentine setup.
    Now I just need to bolt the 454 and other new parts into my tow rig Burban...
  10. tacoma
    Jan 14, 2005
    317
    tooele UT
    DUUUUR now that one should have been obvious to me. I was thinking "grind something to fit" not "grind something to remove it" !! :doah:
    THANK YOU for your help.
  11. blazerbuilder84
    blazerbuilder84 Registered Member
    Sep 28, 2005
    23
    Gothenburg, Ne 69138
    I've toasted 2 700's behind my 454. I'm going to a th400.
  12. tacoma
    Jan 14, 2005
    317
    tooele UT
    yeah, jury's still out here as to whether a 700r4 can be built burly enough for my purposes..... I may just stick w/the 400.
  13. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Watson's having good luck with a 700R4 behind a BBC...but it is a trail rig only.
  14. blazerbuilder84
    Sep 28, 2005
    23
    There's no doubt in my mind that a 700r4 can be built strong enough to take the grunt of a healthy BBC, if you have the coin. I don't. I think it's great that someone has found success with that combo. Unfortunately, I have not. I'll admit that both of mine came out of wrecked Suburbans. If I had a 350 or a 400 in mine, it would be a different story, I'm sure. Oh, well. Wifey wants the big block. Gotta keep mama happy. After all, she bought it for me.
  15. tacoma
    Jan 14, 2005
    317
    tooele UT
    you are the smartest man in this thread!
    I'm tearing apart my wife's DD to swap parts into the trail truck. I am therefore, the dumbest person in this thread.
    Quit snickering. I can admit it! hahahahah
