454 with 700 tranny
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, May 17, 2002.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I am thinking about buying a 454 with fuel injection out of a 92 Suburban, now my question is if my 700 tranny will bolt up to the 454 without any problems.
    Has anybody done this.
  2. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    Yes it will bolt up. Just be sure to verify that the flywheel has the correct bolt pattern for the torque converter before you bolt it together.
    Lonnie
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    A 454 will push a stock 700r4 to its limits. Espically the eariler ones. The stock 700 is only good for around 325 Hp.
    If you are easy on it it may last awhile. But if you have a heavy foot( Kind of hard not to with a big block/forums/images/icons/smile.gif) Plan on putting a built 700 in before too long.
    <a target="_blank" href=http://www.tciauto.com/truck/truck_transmissions.htm> (link)TCI Auto</a> has a line of truck master transmissions that should work very well behind that 454.
    A 700 can be built to handle a 454 no problem but the 4L80 or a TH400 are the best auto trannys to have with a 454
