454bb in 72 blazer which crossmember
Discussion in 'The Garage' started by k2-k5, Apr 12, 2006.
  1. k2-k5
    k2-k5 1/2 ton status
    Sep 30, 2003
    285
    Vancouver, WA
    I have started the BB swap in my blazer.
    before i get to far I am seriously considering moving the engine forward 2" or so to gain more clearance at the firewall.
    I also would like to be able to remove the oil pan so I am looking at using a '73 and newer crossmember. Has anyone done this?
    How much modification is involved?
    Anyone have a spare crossmember layout around? (In the Portland area)
    any other issues with the swap would be appreciated.
    Cheers.
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    PM burt4x4, i think he used a later crossmember when he swapped in his BBC.
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Here it is, you can see it is way forward compared to the under the pan on a stock 72 x-member. It is very close to touching the pan 1/8" or less, Never tried droping the pan but it looks doable.
    Then I found a crack in the x-member so I got ORDs to replace the 73+ x-member.
    The 73+ is a 3 piece> 1 x-member w/ 2 frame horns(engine mounting serface)
    Here is were I got the idea:
    See the top left and center left pics compare the two styles.
    Bottom left shows the engine frame horns or whatever you call um...
    Oh and the ORD x-member is very close to touching also...but it is not..I may make some changes if I feel the need..
    Good Luck
    Burt
  4. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    uhmm why would oyu need a later one ?
    bbc were available in truck 68 and up
    same crossmember
    why swap ?
    its the trees you gotta worry about and mounts
    good luck
  5. Burt4x4
    6,854
    You don't need a newer style to get the BBC in.
    For me I wanted to use the 73+ so I could drop the pan without lifting the engine out..or up. With firstgen x-member the pan will not come out without lifting the engine off the engine mount/x-member.
    Now that I have gone full circle and installed ORD's stuff I now have to drop the X-member to get the pan off but atleast I don't have to lift the engine (still mounted to the 'frame/engine horns').
    One other benny is your engine mounts are now 73 & Up and you have tons of choices on what to run...
  6. '71k204x4454
    '71k204x4454 Registered Member
    Dec 28, 2004
    60
    Hood River Or
    Bbc where not available in 4x4 untill 1973. Yes they where available in the 2wd trucks.
    I'm putting a 1973 and newwer crosmember in mine also. But have not done it yet so don't have any pic's.
  7. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    in the 4x4 yes no bb til 73 yep
    i was jut saying trucks in general
    my bad
    68 was the year in general that 396 first came out for trucks
    but 4x4 no
    good luck
