46 inch tires and D60 question
Discussion in 'The Garage' started by Seventy4Blazer, Jan 4, 2004.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    with 40 spline inners and 35 spline outters 4.88 gears and doubler-465 combo and a diesel or propane injeced 454 be asking to blow up the 60...?
    Grant
  2. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    I pretty confidently say yes. Rockwells are the order of the day for 46s on a heavy truck that sees off road use.
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i tend to agree, however rocks ain't all they're cracked up to be. the shafts are not much larger than a 14FF and they weight a ton more. the shafts tend to be brittle as well and parts are way more expensive. keep the D60, and run a 1350 or 1310 u-joint and it should grenade before the shafts will.
  4. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    You could always try lock out fuses for a built in grenade point. All the major manufacturers use designed weak points for a lot of different reasons. No reason why we shouldn't do the same.
  5. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Whats the point of 40 spline innters and 35 spline outers? the stubs will be the weak point and you will still break... Just go 40 spline throughout with CTM's and drive flanges and you should be ok for a while depending on what your going to do.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    who is selling full on 40 spline setups? I have been looking around the past few days.
  7. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    i didnt know about the 40 spline outters. ethier way i would be planning on molly shafts inner and outer. ctm knucke joints, hub fuses and 1410 drive shaft joints.
    i think with enogh fines it would be alright, but i also am not 100% on the idea.
    i belive superior axle is making the molly shafts for the detroit 40 spline. i have to buy a detroit anyway, and am thinking of the 40 spline unit. i would like to also get molly shafts, so im debating if i should just do it or not.
    Grant
  8. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Superior will make the 40 spline stubs to. But, they will not fit the spindles. You will have to have a custom spindle turned and either new bearings to fit the old wheel hub or a new wheel hub made as well.
  9. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    i think that would be WAY out of budget, but thanks for the info.
    Grant
  10. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    With CTM joints and crmo axles, I can 99.9999% assure you that you will break the hubs first then the ring and or pinion, and or next the drive shaft ujoints. Do Not Run hub fuses in the hubs with locker, they don't last worth a @hit. Besides you can't get them for a 60's anyways IIRC.
    I just spoke with the Superior rep today, through Desert Rat, and he assure us that you will not break Shafts/UJoint with CTM... The weak link is now in the drivetrain, and not in the axles, but that's based on big tires not 49" tires. The moving mass weight of this tire is huge, and a 60 is going to have issues.
    Now, 49's on 60's that's another story, it's tire size and absolute mass with be almost impossible to run in the rocks. We have one at the shop, and they are huge, and are VERY HEAVY. I would assure you that running these tires in the rocks is a certain breakage gona happen, period!
    Rob
  11. Jim Johnson
    Jim Johnson Registered Member
    Jan 26, 2003
    64
    Middle, TN
    Grant
    I have a friend running 46 Michelins, Ford D60, doubler and 302 with 1350 joints, 35 spline outers.....He hammers on it hard, and he has not had any problems ( his truck is pretty light as well)
  12. Jim Johnson
    Jan 26, 2003
    64
    Middle, TN
    Curious - Are you guys actually breaking the 35 spline set up and need the 40 splines? or do you just want them to have them?.....
  13. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    well, i play VERY hard on EVERYTHING i own. my 2wd 2003 sonoma had more dents, dings, stains, bruises and miles on it than it should have. drive it like you rented it is my motto. and i do. a few people here can verify this. if i decide to get 46's then i will go 40 spline inners, 35 spline outters, bullets, and CTM for the front. thats cash, and im soon to have a lot more of it.
    i do however thing that i will stay with getting the 42's. i think 4.10's 42's SM465 and the doubler will hold me out. while i am overseas im going to save up and get a 502 replacement for my dually. then the 454 is getting a propane injection setup and going in the blazer.
    it is by far NOT going to be a light rig at all. so 46's and a 60 would give me problems i think.
    thanks for the input guys. i guess 46's will be on the next rig i own.
    Grant
