465/205/44/14ff 4.10 Gears Warn Hubs Moded For 15in Wheels
Discussion in 'Suspension | Axle' started by gn4u2c, Sep 7, 2005.
  1. gn4u2c
    gn4u2c 1/2 ton status
    Oct 29, 2003
    287
    Pa 17329 zip
    These are in great shape bolt in and go ! raised sreeing arm for 4-6 inch lift, warn lockouts, good brakes, everything is tight. drum/drum hub/hub nothing missing $400.00 for the set
    sm465 works great $150.00
    205 with 465 adaptor $150.00
    I have everything you need still on the truck ! This is a complete truck at the moment will be parting as needed. If you need everything to switch to 4 speed I have it all - colum.
    6' lift front springs , rear blocks, superlift shocks with red boots u bolts and all. this kit looks to be fairly new as the shocks do not have any scrapes or rust on them. u bolts are not rusted ither. $150.00 for it all
    driveshafts for lb truck $25.00 rear, $50.00 for the front very tight.
    Must pickup parts unless you arrange and pay for transport I will help load.
    all parts from 1976 truck with low miles but rusted up as most are.
    Glenville Pa 17329 zip. pm me me for details or a time to pick stuff up. I will need a few hours to remove the parts for you before you come.
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    is the front driveshaft for a yoke or flange style output on the TC?
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    u wouldnt happen to have the 15" 8 luggers would you? if so, let me know. i need some asap!
  4. gn4u2c
    Oct 29, 2003
    287
    Pa 17329 zip
    wheels sold
    bolt in front driveshaft
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    would u part out the front? im looking for 8 lug conversion. let me know.
  6. gn4u2c
    Oct 29, 2003
    287
    Pa 17329 zip
    I have several other 44's that are 8 lug yes I will part or you can stop up and pick up a hole working 8 lug front for $100.00
    let me know 443-398-7326
    jason
    just off I-83 exit for middletown rd
