465/205 adapter mount problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Langosta39, Feb 26, 2003.
  1. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    So I'm installing my transfer case crossmember-to-adatper bolts and I get them to about 5 ft/lbs and they strip. Well crap! I'm thinking about drilling the adapter holes all the way through then grinding the top flat to accomodate a bolt and nut setup. Anyone think this is a bad idea, or anyone done this before? I assume the adapter is cast iron, correct me if I'm wrong, so it could handle missing a bit of extra metal. On a side note, is cast iron hard to drill or grind? I don't know my materials very well.
    later,
    andy
  2. dyeager535
    26,978
    Yes the adapter is cast iron.
    No, I don't know if the nut/bolt idea will work, but I do know the adapters are real weak (comparatively) in the threaded section there. If you did the nut/bolt idea, I'd imagine the top surface would have to be flat, which it's not as I recall. If its not flat, you won't get even clamping pressure, and stress the already weak area more.
    You could use threadserts.
    I did approx 20 1/2" holes through cast iron GM heads with one carbide bit, and a drill press, it was a piece of cake. Bit cost about $20, but it worked.
  3. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Whwn I got the "truck blazer", it had one bolt all the way through one side of the adapter with a nut on the top. I think they just got a longer bolt, threaded it all the way up, and tightened down a nut up top. It's never came loose on me, and I've never had to mess with it myself.
  4. Langosta39
    Nov 8, 2002
    156
    Moscow, Idaho
    What exactally are threadserts? If I have to drill the adapter for those I might as well drill all the way through a use a bolt/nut so I don't have anymore probs. You said the adapters are weak in this area, do you think it would hurt its integrity by drilling and grinding?
    andy
  5. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Just do what you said you were gonna do. Drill the hole out to 1/2", grind the top flat, and put a gr.5 or 8 bolt in it. I have been running like this for years and it is not the weak area. Cast is easier to drill and grind than mild steel. It grinds very quickly.
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    later,
    andy
    That's exactly what happened to me and exactly what I did, and it works.
    You don't have to drill or tap, it's threaded all the way or at least mine was, I just milled the top flat and put a nut on it. Between the stripped threads and the nut on top it held to gether just fine.
    Another weaknes I have seen is the outer part breaking off from side loads.
    It's cast so it's brittle and it can break that way.
    I was thinking the other day just to make sure this doesn't hapen to me, I would make a strap and go around from side to side to keep it together using a steel strap.
  7. Langosta39
    Nov 8, 2002
    156
    Moscow, Idaho
    You mean using some plumbers tape or something thicker to go over the adapter to hold it down from twisting?
    seems like it could work, i actually had a similar idea but didnt know if it was a good one.
    andy
  8. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    andy
    NO
    You know how the bottom has like 2 legs each with a bolt through it?
    Well the sides sometimes chip of, and welding them isn't an easy option so to protect them before they break, wrap a steel strap, like what they use to strap crates but a little thicker and wider like 2" wide, that will reinforce it.
    I will have a pic soon once I make it.
    /forums/images/graemlins/thumb.gif
  9. dyeager535
    26,978
    Threadserts are basically the same idea as heli-coils, except use standard taps.
    If everyone else is just using a nut/bolt arrangement (with the top milled flat) do that.
    Regardless, the bolt holes *are* a weak area, my first adapter was broken right there, and I'm not the only one here that has had the same problem.
