465/205 oil seals
Discussion in 'The Garage' started by Rusty68, Jun 21, 2004.
  1. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    I went to check the oil in my transfer case, and when I pulled the top plug out oil came gushing out. I meen like almost 2 quarts over filled. This has me wondering, is there some form of oil seal that could be letting the transmission oil into the 205? On that note the tranny oil was also low. There is no sign of leaking except oil coming out the breather of the transfer case. Any wisdom? /forums/images/graemlins/ears.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i think there is a seal in the adapter, but not sure. /forums/images/graemlins/thinking.gif
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    yes there is a seal between the tranny and t-case. and if your tranny always is loosing fluid and your t-case is over filled, I can almost gaurentee this is the problem...
    Chris
  4. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    found one of the seal I bought from GM (I bought 3 last time b/c they NEVER have them in stock) it is GM#03968050
    Chris
  5. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    So there is one. Is it in the adapter? would napa carry this or do I have to get it from a tranny shop
  6. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    Ok thanks alot! Just off the top of your head, do you know some place that sells a complete seal kit? If I have to drop the case I may as well freshen it up.
  7. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Napa #13676. But I am not a huge fan of CR seals so I wend with the GM (National) seal even though it cost a bit more
    Chris
  8. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    oh, and I got my seal/gasket kit for my sm465 and NP205 from ORD, but the kit did NOT include the adapter seal of which we are speaking.
    Chris
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    national drivetrain is in reno think
    thats who I ordered my rebuild kit from last time
    FYI you have to use gaskets not silicone between the adapter and the gearboxes
    the gasket thickness is part of the relief distance needed to clear the snap ring that retains the bearings
