465/205 ?'s
Discussion in 'OffRoad Design' started by BigOrange90Jimmy, Jul 30, 2002.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    465/205 ?\'s
    Alright, I just bought a 465/205 combo from a late 70's pickup. What do I need to check out in this thing before I install it in my 90 Jimmy? I'm also going to a 14b rear and some sort of 8-lug front when I find it. Give me some tips on what I need. Thanks, Ash
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Re: 465/205 ?\'s
    Since you posted here in ORD forum , shall we presume you are wanting to install the doubler?
    Or are you looking for advice on how to rebuild/recondition the 465/205 before you put it in your rig?
  3. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    Re: 465/205 ?\'s
    Well I was referring to reconditioning before I put it in, but the Doubler info could be well used also /forums/images/icons/wink.gif
  4. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    Re: 465/205 ?\'s
    nothing, huh?
  5. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Re: 465/205 ?\'s
    Hey lets go wheelin! Anyways I would check the obvious stuff first like the seals,and shift the tranny.it should shift freely but may be a little difficult into granny,thats normal.Check the input shaft bearing retainer,where the throwout bearing rides,should be smooth with no grooves or burrs.These things are tough as nails and really shouldnt be alot wrong but without tearing it down to check condition of bearings and gears if there was something wrong with it that isnt obviuos you cant tell without running it..................Mines out of a 79 and ive gone through my first clutch.lord knows how many cluthes before mine and it still runs flawlessly!
  6. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    Re: 465/205 ?\'s
    you should seperate the 2 and check the drive sleeve and the2 shafts for wear,it seems to be one of the mostcommon things on that combo,cause its probably a 10 spline ....
  7. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    Re: 465/205 ?\'s
    If there is any wear, is there any way to beef it up? Or where could i get the stock replacement?
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Re: 465/205 ?\'s
    We carry new drivesleeves and have good used input gears in stock. An output shaft for the SM465 would probably be a new part from us.
  9. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    Re: 465/205 ?\'s
    alright, well let me get it apart and if anything is wrong, i'll be getting up with you. thanks
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Re: 465/205 ?\'s
    what is a new output worth?
    I need 2
