465/208 to 465/205... what parts are needed?
Discussion in 'OffRoad Design' started by TruckNutzDude, Mar 26, 2004.
  1. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I have the 10 splined 205 with adapter for my 465 and a 465 with a 208 behind it. I want to mate the 205 to the 32 splined 465. What parts do I need for this setup and what, if any, machining is required? Thank you for your help /forums/images/graemlins/thumb.gif
    I got this information from your website /forums/images/graemlins/bow.gif
    <font color="green"> NP205 input conversion kits: </font>
    Convert your male input NP205 to a TH400 version 32 spline female input gear. Kit includes new input gear, input bearing and a seal and gasket kit. Requires machine work on the NP205 case to install. Gear bearing and seal and gasket kit also sold separately.
    Price - $200.00
    <font color="green"> NP205 front output shafts: </font>
    Change your weaker 10 spline shaft to a stronger fine spline version in either 30 or 32 spline. Both the 30 and 32 spline are very strong, the practical difference is the 32 spline shaft has more yoke options available.
    30 spline front output shaft for NP205 - $160.00
    32 spline front output shaft for NP205 - $120.00 (32 spline front output pricing subject to availability, and we don't always have them in stock.)
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You need the long 32 spline input and the rare as hens teeth 85-91 SM 465/465 adapter and the crossmember for the round pattern.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, what Tim said is what you need. And I've got just what you're looking for. My price may sound high, but try finding one and getting one cheaper than the boneyards. PM me if interested. /forums/images/graemlins/waytogo.gif
  4. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    You've got a PM /forums/images/graemlins/grin.gif
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Oh yeah, forgot to tell you when you were here. Wes is a straight shooter. buy with confidence!!
  6. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    He sounds like a nice guy and so far I haven't heard of any complaints.
    I realized I forgot to give you the flexplate w/ that tranny when I got home. If you really need it I'll mail it to you along w/ the bracket for the shift linkage to the frame.
    Who shimmed that starter anyways? It ate the flywheel! Good thing I was buying a new one anyways /forums/images/graemlins/waytogo.gif
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    There is another way, we have an adapter plate that lets you use the 10 spline adapter housing, the short 32 spline input gear in the 205, and the long 32 spline output shaft in the 465. It's not quite as bolt on as a factory 465/205 setup, but if you have a fig 8 bolt pattern 205, it's all you can do.
    Going with the late model method, you have to have the adapter housing, round pattern NP205, and the long input gear in it. Those parts are hard to find.
  8. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I can get an entire 465 with a 205 attatched from the factory but it's the 10 splined version. I just heard that the 32 splined combo was stronger. I think I'll run my 10 splined 205 and save my money for a factory 465 to 205 32 spline adapter and round pattern 205. I'll just carry spare parts until then (10 splined collar and the tranny to t-case adapter) Thanks for the information, I'll be saving this in thread for later use /forums/images/graemlins/grin.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Wish I'd known that 6 months ago, I could have eliminated my 10 spline crap and gone with that instead.
  10. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I had to bring this up again. Can I bolt the 10 spline adapter to the 32 spline transmission and put a 32 splined input shaft in my 205 (figure 8 pattern)? I have the 32 splined 465 and the 10 splined 205 with adapter already.
  11. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yes, you use the 32 spl. output, 10 spline adapter, 32 spline input gear in a fig8 case and our short adapter plate between the 205 and the 10 spline adapter housing.
  12. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Whats the price on your adapter plate? I had started to design my own but I bet it would cost more to have one custom made compared to buying from you guys /forums/images/graemlins/thinking.gif
  13. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    What's the purpose of the adapter plate? I thought all SM465's used the same bolt pattern and that it was just the main shaft that had changed. /forums/images/graemlins/dunno.gif
  14. kennyw
    Jun 9, 2002
    13,223
    94
    To use the short 32 spline input (TH400 version) on the long shaft 32 spline SM465 with the figure 8 adapter (originaly a 10 spline sm465 application) you need an adapter/spacer plate that is about 1" thick for the correct spine engagement (or you could risk cutting off the end of the shaft but it is not advisable).
    Basically you are mixing and matching GM parts to get the combo they should have produced from the factory. /forums/images/graemlins/thumb.gif
  15. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I'm a machinest, a plate like that shouldn't be too hard to fab up but it might be time consuming. How much does ORD charge for the adapter and the input shaft? I'm almost ready to place an order but a price would be helpful so I know if my bank account will be able to handle the charges /forums/images/graemlins/wink.gif
  16. kennyw
    Jun 9, 2002
    13,223
    94
  17. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    ouch! That brings the price up to around $300, and for $300 I could easily find a new style 205 with 32 splines. My wallet hurts already /forums/images/graemlins/doah.gif
  18. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    If you can find a round pattern 205 with the factory 465/205 adapter housing for $300, this kit's definitely not for you.
    "I have this really clean '91 crewcab...."
    "the farmer next door had this one ton that he just wanted hauled off....."
    "I had to pay $300 for it at an auction but somebody had already swapped a cummins into it...."
    I think I might have another entry for my list of things I wish would happen to me.
  19. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    You're a funny guy Stephen /forums/images/graemlins/waytogo.gif I'll be placing my order in a few weeks /forums/images/graemlins/deal.gif
